Threads: 42
2
Given 0 thank(s) in 0 post(s)
Just wondering if it's ok to run a 306 with bosch pump on sunflower oil? As I've just got a load cheap. And wondering what the main difference would be in running just normal veg oil and sunflower oil (I'm new to running it!)
Any advice appreciated
Threads: 61
4
Given 6 thank(s) in 5 post(s)
Sunflower oil is fine mate. It is actually better imo it smells better and is thinner so it's better on startup
Threads: 42
2
(12-07-2014, 10:09 PM)aggyj17 Wrote: Sunflower oil is fine mate. It is actually better imo it smells better and is thinner so it's better on startup
Cheers just got 50L from tesco for £40
Gonna get some more while it's on offer
Threads: 61
4
The 2 5l for £8 deal. That's where I've been going aswell :-)
Threads: 42
2
(12-07-2014, 10:14 PM)aggyj17 Wrote: The 2 5l for £8 deal. That's where I've been going aswell :-)
Yeah, only noticed other day so thought I would give it a go haha
Threads: 87
48
Car Model/Spec: Rouge vallelunga 5 door Dturbo
Given 74 thank(s) in 70 post(s)
that's the stuff . . .
Threads: 3
Its really hard to start on Sunflower oil
Threads: 87
48
(17-07-2014, 09:09 AM)kelvsere Wrote: Its really hard to start on Sunflower oil
easier than veg or soya . . . . .and it shouldn't be hard to start at all, sounds like you need new glow plugs fella. . . .
guess you're just getting your post count up, i'll leave you to it then lol
Threads: 3
Haha yes trying to , i used to have a corsa D , it wouldnt start on sunflower oil at at all , it was a bag of %^&**& though, started easy on pure veg , so must be a diff
Threads: 87
48
(17-07-2014, 09:14 AM)kelvsere Wrote: Haha yes trying to , i used to have a corsa D , it wouldnt start on sunflower oil at at all , it was a bag of %^&**& though, started easy on pure veg , so must be a diff
yes there is, sunflower is quite a bit better than veg . .so don't understand that problem at all.
Threads: 82
27
Car Model/Spec: E92 335i, GTi6, HDi S2
Given 22 thank(s) in 22 post(s)
Corsa D's are CR engines aren't they? That'd probably explain it lol..
Threads: 3
Yeah i wasnt expecting it not to like it but it only just started on the stuff , i tried it a second time by using half veg and half sun , and it took a fair few turnovers to kick up .
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Given 41 thank(s) in 38 post(s)
long as it doesnt have palm oil in the mix you should be fine.. palm oil has a higher gel temperature which means you will run into problems with it if it gets cold!
/Toseland
Threads: 6
Is there a specific pump you need for this - I was led to believe there are two possible types - Bosch and Lucas.
But the seals on the Lucas wont last.
My has been at this for a while on Audi's - he has a preheater tank for Winter time and also he recommended adding some diesel to the mix to keep the tank circulating....
I've done this before with a Citron BX estate with 100% ra*e seed iol and it was grand - we called it the batter burger cos of the smell from behind......
Threads: 591
54
ra*e seed oil is top stuff but noramlly most expensive...
a quick search will find 100s of threads asking what pump to use for veg...answer is always the same - BOSCH!
