Threads: 371
29
Car Model/Spec: ford fiesta
As title has anyone done this? I wouldn't foresee it being an issue but you never know. Surely would only result in more braking force to the rear. Converting to discs on rear soon and want to drop it off basically.
Threads: 87
48
yes i did it on my old 1.6, it's ok 99% of the time but slam on full and you can lose the back end . . up to you ..
Threads: 371
29
Ah I see. Might get a reducer in the brake line as well. I'm sure they exist
Threads: 31
Car Model/Spec: tu5 bitza/cherry dt
Given 5 thank(s) in 5 post(s)
just get a cheap bias valve if your a bit unsure, ive been running my 1.6 without the comp for 2 years i think and only had the rear lock in extreme wet weather.
im running 266mm fronts brembo discs mintex pads and standard rear discs same again brembo and mintex
Threads: 371
29
That's basically what I'm going to be running. Just with braided hoses too. I'll have a look at bias valve
