10-04-2014, 11:45 AM
£30 on ECP with discount anyway lol.
And, nope, mine gets louder with revs, it's bloody annoying at motorway speeds!
Belt Area Squeal - PAS Pump?
10-04-2014, 05:31 PM
Is it leaking on the belt causing slip mone was!
As above, if the belt is tight and squealing isn't cured by revs then there's another issue. The tensioners can take up quite a lot of slack between them, could probably just about use a 1190 tbh.
10-04-2014, 07:48 PM
(10-04-2014, 05:31 PM)pugmanxud Wrote: Is it leaking on the belt causing slip mone was! Wasn't leaking, but replaced now anyway...squeal disappeared for a short while before coming back. (10-04-2014, 06:38 PM)Poodle Wrote: As above, if the belt is tight and squealing isn't cured by revs then there's another issue. The tensioners can take up quite a lot of slack between them, could probably just about use a 1190 tbh. Ah I didn't realise that, thought the belt tolerances were a little smaller tbh. Ordered one now anyway, 1183. |
Cost of Timing Belt and Water Pump Replacement? | JTaylor2005 | 7 | 2,537 |
12-02-2018, 03:29 PM Last Post: JTaylor2005 |
Best timing belt kit and water pump? | JTaylor2005 | 13 | 3,329 |
23-09-2016, 10:11 AM Last Post: BiG K |
Squeal when turning wheel | DTubZz | 5 | 1,277 |
24-04-2014, 07:31 AM Last Post: DTubZz |
