15-03-2014, 09:23 PM
I have three dim lights (not battery light) staying on on the instrument panel that won't go out even with the ignition key removed. Also the car will not start as there is no 12v power to the white wires on the coil (Bosch system). I have disconnected the ecu, management relay and all relays in engine and fusebox inside the car. Anyone any ideas. thanks
