30-01-2014, 01:11 PM
Anyone know the factory settings for fuel pump and compensator. Turns out/ in etc . Thanks
fuel pump / compensator factory settings
30-01-2014, 01:16 PM
Tbh mate, each pump can have different settings. Do you know what pump you've got?
30-01-2014, 01:24 PM
It's a lucas mate. It's running max at minute. Boost comp is quite wound out. Supposedly running 28 psi on a td04 hybrid . Not got a boost gauge to check at minute. Not so much bothered at standard just so she stops smoking
30-01-2014, 02:13 PM
Personally, I'd get a boost gauge on asap, but all you need to do is wind back the max fuel till it blows clean on boost really. Do you know how to get to the max fuel screw?
30-01-2014, 02:31 PM
Yes mate little cover on front and then Alan key bolt . Can I do it whilst car running or do I have to stop reset start again etc ?
30-01-2014, 02:53 PM
You have to have the car off, once you remove the black cap it will empty your fuel pump of dielse, you then need to rotate the engine till the allen key is visible you will need a mirror at an angle to see it tho as its set deep inside the pump. once you turned it down abit you will need to prime the pump back up with derv, and get any air out.... then start it again
I would have a try messing with the boost compositor first if you can. Would have doubts about the said psi with out a boost gauge you wouldn't no what psi its at.
30-01-2014, 03:01 PM
Cheers mate . Will have a crack at weekend. And the psi was from what the previous owner3 weeks ago had said . He still has the boost gauge which Ii am trying to get off him . Thanks for the help .
30-01-2014, 05:33 PM
Wind the boost compensator in to cut smoke down. The td04 will need the max fuel maxed.
93 106 xsi
98 306 1.9d 98 306 1.9td lx 01 306 2.0hdi 97 306 1.9td estate 96 306 dturbo 96 306 dturbo
31-01-2014, 05:41 PM
Okay thanks . Will wind boost compensator down see if I can get rid of smoke don't mind a bit . And how would I know what turbo it is ?
31-01-2014, 06:19 PM
(31-01-2014, 05:41 PM)dwanepipe Wrote: Okay thanks . Will wind boost compensator down see if I can get rid of smoke don't mind a bit . And how would I know what turbo it is ? Look on it for numbers or codes, or throw some pics up few people will be able to tell with just looking ![]()
31-01-2014, 06:31 PM
No worries. Got told by 2 previous owner so it has a td04 so will make sure . Buying boost gauge and mbc next weekend and see what psi she's running
31-01-2014, 07:19 PM
No mate 3dr red.
Bosch pump fuel screw broken | Forby | 0 | 1,596 |
12-03-2019, 06:47 PM Last Post: Forby |
Cold start issue- fuel pump? | Blaze Addict | 3 | 1,918 |
20-01-2019, 11:10 AM Last Post: Martin306 |
Is immobiliser coded to fuel pump? | Huddo | 2 | 1,637 |
07-12-2018, 03:04 PM Last Post: Ruan |
