Threads: 41
Hello all.
Im replacing my 306 1.9 TD DTurbo XUD9 engine from another car.
Wheather its a good idea to replace what bits to whilst engine is out?
Timing Belt?
Tensioner?
Waterpump?
Clutch Kit?
Clutch Cable?
Anything else?
Thanks
Sam
Threads: 226
24
Car Model/Spec: A3 TDi
I'd be tempted to do the headgasket if you havent seen it running.
Threads: 33
Car Model/Spec: 306 D-turbo/306 Rallye
As tom said, also id put a new cambelt and tensioners and waterpump on it too..
Blaze '6 and Blaze D-turbo!
Threads: 226
24
Yeah i meant i'd do everything you've said, plus HG if you havent seen the engine running and had a proper inspection of it.
Threads: 110
20
All depend how far you want to go with it and how much money you want to spend on it. Would say cam belt, tensioners and water pump as a minimum as there a lot easier to do with the engine out
Threads: 41
Engine running well, wanted to do most works as will be keeping car until it dies.
