	Threads: 465
114
Car Model/Spec: Vauxhall
	Given 98 thank(s) in 92 post(s)
		T5 or 286
1 in the dash lcd
2 in the clock/temp display
	Threads: 2
	Given 0 thank(s) in 0 post(s)
		Be warned of the ones that come in the B8.5 type twist cap, as they do not fit (you can take the LED bulb out and swap in almost everything easily, except in the heater controls
	Threads: 183
20
Car Model/Spec: moonstone hdi #2
	Given 8 thank(s) in 8 post(s)
		Do have to solder the ones for the lucky windows?
![[Image: 6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg]](http://i512.photobucket.com/albums/t326/kent16_2008/6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg)
	Threads: 183
20
		Do I need rounded end or flat?
	Threads: 2
		Apparently flat are less likely to give you a 'hot spot' of light, I had some round ones, and used a permament black marker on the tip, which seemed to reduce the 'hot spot'.
As for 'lucky windows', do you mean the electric switches in the door? If so, yes, I believe you do need to solder/ de-solder  them.
