20-01-2014, 10:30 PM
pics of my axle
21-01-2014, 11:22 PM
Second pic doesnt look so good. But then rear beams is one thing i have zero experience with, just looks a little to brown for my liking.
22-01-2014, 10:14 PM
Those mounts do look old so could well be clunking, so worth changing first, don;t forget the rear ones as well
Beam wise make sure the trailing arm in parallel to the beam tube, With the seal in good condition, this gives a idea on the beam condition.
26-01-2014, 08:20 PM
I guess you could argue that even if you buy a 2nd hand axle, you might want to replace the mounts anyway, so possibly worth trying new mounts on your current axle, then if this doesn't work, get a 2nd hand axle and move the new mounts across to it. How much are mounts these days? Can't remember from when I did mine.
26-01-2014, 08:54 PM
do the mounts first
the mount is held together with a pin in a hole when the rubber gets soft or delaminates the pin bumps around in the hole causing the knocking noise
27-01-2014, 05:07 PM
If your going to get new mounts don't get the cheap eBay ones I had one where the rubber snapped clean off after a few months.
Bye Bye D-Turbo
Phase 1 GTi-6 now has a new owner Rolling in the: Phase 3 HDI Wagon The current estate project: http://306oc.co.uk/forum/thread-22237.html |
![[Image: DSC_1139.jpg]](http://i97.photobucket.com/albums/l214/paul7278/DSC_1139.jpg)
![[Image: DSC_1137.jpg]](http://i97.photobucket.com/albums/l214/paul7278/DSC_1137.jpg)
![[Image: DSC_1140.jpg]](http://i97.photobucket.com/albums/l214/paul7278/DSC_1140.jpg)
![[Image: cornishmafia.jpg]](http://i97.photobucket.com/albums/l214/paul7278/cornishmafia.jpg)
