Car won't start.
Car won't start.
I have just finished changing the heater matrix in my 2001 306 and it won't start it turns over but won't fire. Any ideas what might be the problem? Thanks.
What engine mate?
Team Doesn't own a 306
Its a 2ltr twin cam 5speed rallye 2001 model. could it be something to do with the imobiliser?
Possible. Did you unplug the ring around the ignition?
Do you know if its getting a spark or fuel?
Yes I had to unplug the immobiliser to move the dash, I haven't checked for fuel or spark yet.
inertia switch probably got a knock
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Where is the inertia switch?
Behind the battery near the bulkhead, red rubber top!!
[Image: Sig3_zpscd005eb1.jpg]
When you flick the key to the second stage, can you hear the fuel pump under the back seats priming? If not, check the inertia switch and also check the two large multi plugs under the glove box are connected properly.
I can't hear the fuel pump,and there is no spark. I have pressed the inertia switch and rechecked all the multi plugs. There is a red stop sign in the middle of the dash which is staying on when the key is at the second stage.
Did you disconnect the battery when you done it have you tried locking unlocking the car
Yes I disconnected the battery well before I started work and the central locking still works.
