Threads: 343
15
Car Model/Spec: 106 gti / 306 hdi estate
Given 3 thank(s) in 3 post(s)
29-12-2013, 10:39 AM
(This post was last modified: 07-01-2014, 08:52 PM by Chris_90.)
So im stripping the head down ready to be skimed, took cam out, but i carnt work out how to remove the valves?
So how do i do it?
P.s This is a learning curve for me so no stupid answers please (i no thats a big ask )
Threads: 177
3
29-12-2013, 10:46 AM
(This post was last modified: 29-12-2013, 10:48 AM by Daniel306.)
You need a valve compressor, then you need to remove the collects.
Threads: 343
15
29-12-2013, 11:00 AM
(This post was last modified: 29-12-2013, 11:03 AM by Chris_90.)
Oh..... I see now well the issue i was having is were is the spring/ collets (how ever its spelt)
Oooooo There they are
Thanks for the vid Daniel
p.s did you get my pm?
Any one recommend a valve spring compressor for the job?
Threads: 136
11
Threads: 129
11
Is this the head with the broken valve? If so I'd avoid using it as the valve shaft may have been damaged, not noticeable to the eye and cause an oil leak or worse
Stage 2 XUD Sedan
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 31 thank(s) in 31 post(s)
not sure if that video mentions, but you need to keep everything in order for re-assembly
Threads: 343
15
(29-12-2013, 11:28 AM)strictly_perv Wrote: Is this the head with the broken valve? If so I'd avoid using it as the valve shaft may have been damaged, not noticeable to the eye and cause an oil leak or worse
No that head has big BIG chunks and gorges in it from were valve as hit it, so just got a another engine.
(29-12-2013, 12:04 PM)zx_volcane Wrote: not sure if that video mentions, but you need to keep everything in order for re-assembly
Yer I was thinking this tbh I plan on making a bord to put every thing on in order.
I'm sure there will be more questions on this when I come to rebuilding it, but won't be for a while till I got money for gasket Kit and money to get it skimmed.
Threads: 591
54
Dam just seen where you are otherwise I would drop my tools round...
Spring compressor is invaluable really to do this
Once done...get the valves in a drill with some wet n dry paper and get them spanking clean!
Also worth buying a valve lapper and paste
Threads: 465
114
Car Model/Spec: Vauxhall
Threads: 226
24
Car Model/Spec: A3 TDi
Hammer and a deep socket
Threads: 343
15
(29-12-2013, 01:12 PM)Piggy Wrote: Dam just seen where you are otherwise I would drop my tools round...
Yer was gonna look in to the valve lapper thingy, what grade wet a dry should I use?
(29-12-2013, 01:19 PM)cully Wrote: http://306oc.co.uk/forum/thread-17479-po...#pid340753
Thanks Will read though that when I get chance should help out
(29-12-2013, 01:29 PM)Tom Wrote: Hammer and a deep socket
I have issues with hammers every time I use one I always brake something and then takes 3 Times as long to fix what I just messed up
Threads: 591
54
Hammer n socket get then off all right...but are no help in getting them back together!!!
Something like 400grade to begin with.
I wouldnt reccomend it but I use a careful blunt screwdriver to get the worst off first...be careful though and have the drill in a vice
Threads: 49
2
Car Model/Spec: 306 HDI Estate + 205 HDI
I use BBQ cleaner to clean carbon deposits off stuff, works reet good. Will also dissolve ceramic coatings off piston skirts so be careful what you spray it on. After that as above Drill, scotchbrite lap in.
Threads: 16
Car Model/Spec: 406TD/XUD Corolla/lolvan
Given 1 thank(s) in 1 post(s)
I used one of these
Mind your shims under the buckets, don't lose them! Mind the collets too
As for lapping the valves, well worthwhile. Found some of mine were heavily pitted, required the other end of the tin of paste....
While you have the head off, look for blobs of casting in the ports and dress them out
Threads: 591
54
29-12-2013, 04:03 PM
(This post was last modified: 29-12-2013, 04:04 PM by Piggy.)
yeah thats a valve spring compressor!
you need to use the coarse valve paste THEN the fine ideally
Threads: 151
14
Car Model/Spec: 306 D-turbo
Don't know why people strip them? Take mine to a local engine rebuilding specialist unbolt it off the car and take it straight to them £30 later it's skimmed
Team Doesn't own a 306
Threads: 591
54
but if you have the head off, lapping the valves in is a given to be honest imo
And I wana come to your engineering firm...my local charged me over a £100 for a skim n test
I miss my old town where I could get them for £25
Threads: 343
15
(29-12-2013, 04:09 PM)Danny2009 Wrote: Don't know why people strip them? Take mine to a local engine rebuilding specialist unbolt it off the car and take it straight to them £30 later it's skimmed
I'm striping it so can have valve stem seals etc why it's in bits, if your gonna do a job men as well do it right first time.
Do I really need to clean the carbon off the valves? Cos there gonna get dirty again soon as its started up.
Gonna lap them why there out tho
Threads: 591
54
29-12-2013, 05:11 PM
(This post was last modified: 29-12-2013, 05:11 PM by Piggy.)
You be amazed how much carbon has built up on them
Fyi lap them with the valve stem seals out
Threads: 343
15
(29-12-2013, 05:11 PM)Piggy Wrote: You be amazed how much carbon has built up on them
Ok, well not doing this yet as not got money for bits yet, was just having a nosy why I was filtering oil in shed earlier.
Is it worth renewing the fire seals on the injector ports to?
Threads: 591
54
Oh yeah...but they normally come with the headset.
Fire seals and copper seals, IE two for each injector
Threads: 343
15
This is the head gasket set I'm looking at buying, it any good? And is that every thing I need? (minus the bolts)
http://pages.ebay.com/link/?nav=item.vie...0283046466
If that's no good any one got links to a decent one?
Threads: 591
54
Seems a bit cheap to be honest
Payen or Victor Reinz would be my only preference
Threads: 151
14
I'd buy that looks decent then just buy a payen or victor reinz headgasket
Seems silly but them inlet gaskets are £10 on there own from my local factors so worth it if you think about it
Threads: 343
15
29-12-2013, 08:26 PM
(This post was last modified: 29-12-2013, 08:34 PM by Chris_90.)
Ok then if that's the case probably better getting this genuine Peugeot Kit, then find a decent head gasket.
http://pages.ebay.com/link/?nav=item.vie...1232003434
Surely be better genuine Peugeot Kit?
Maybe this head gasket? (still looking tho)
Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item.vie...1145853806
Threads: 151
14
That head set looks ok
But mate get a payen on reinz headgasket or as soon as you come on boost you will be changing it again
Threads: 343
15
(29-12-2013, 08:52 PM)Danny2009 Wrote: That head set looks ok
That gasket is Victor reinz one?
Threads: 343
15
Got some more questions guys, what sandpaper shal I use on the block deck? Also what sandpaper for getting carbon of the lip of the boars to take pistons/rods out?
Any tips or hints on removing pistons/conrods?
Thanks in advance
Threads: 7
2
Car Model/Spec: 106 slo-nad
Given 7 thank(s) in 7 post(s)
I use scotchbrite to remove deposits.
Threads: 226
24
I used quite a coarse black paper. Just bought a halfords hobby kit they call it i think. Used one of the rougher black sheets, just go easy. <<< That was for the lip on the cylinder.
