Threads: 6
Car Model/Spec: Peugeot 306 1.8
Given 0 thank(s) in 0 post(s)
looking for some help please on my car the ignition has been changed as original key was snapped however the door barrels haven't so i cant lock the car i am looking to buy some today is there any difference in the barrels from central locking to manual and the best place to buy them
thanks
Threads: 591
54
Your ph3 will have central locking as standard
Threads: 6
yes it has i need to get new barrels so just wondering if i need to get a specific barrel
Threads: 591
54
Ah I see.
just any lock set from another ph3.
Threads: 42
28
Given 89 thank(s) in 88 post(s)
28-12-2013, 01:56 PM
(This post was last modified: 28-12-2013, 01:57 PM by welshpug.)
no, they're all the same, and VERY easy to swap, all you need is a 4" long wood or chipboard screw, around an 8, it''ll take a few seconds each side to swap them.
the beaters (the plastic lever) is specific to each side from memory, so make sure you pop it in the right side.
Threads: 42
28
open door, remove rubber bung in the dor end, wind screw in, pull on screw.
pull loose lock barrel from door, fit new one, push clip back on, replace rubber bung.
