Threads: 119
5
Car Model/Spec: MG ZS180
You may find they sit too far in the arches without spacers.
Threads: 541
124
Yeah 50 is quite a far in offset. Depending on what they are going on 9" is pretty wide.
Threads: 94
24-11-2013, 06:06 PM
(This post was last modified: 24-11-2013, 06:10 PM by Bananalad.)
So higher the offset the more tuck?
The alloys are off an Audi Q7 and going on an Audi A4
Threads: 79
17
Car Model/Spec: Down and out HDi racestate
24-11-2013, 07:41 PM
(This post was last modified: 24-11-2013, 07:43 PM by Slam Wagon.)
Yup, higher offset means they sit further in, dont forget adapters will be 15-20mm so will make the offset 30-35
Threads: 6
24-11-2013, 08:32 PM
(This post was last modified: 24-11-2013, 08:33 PM by Andy!.)
surely the spacers will increase the offset and push the wheels even further out?
offset is measured from the centreline no?
Threads: 79
17
24-11-2013, 08:58 PM
(This post was last modified: 24-11-2013, 08:59 PM by Slam Wagon.)
Offset is measured from the centre line, but the lower the offset the further out the lip is.
Threads: 6
24-11-2013, 09:26 PM
(This post was last modified: 24-11-2013, 09:27 PM by Andy!.)
exactly, +ve offset higher the number the further out from the centreline so the further in the wheel.
hence why a 206 alloy sits too far in on a 306 (offset on a 206 is larger than a 306). So by adding spacers you are lowering the offset and pushing the wheel outwards.
