31-10-2013, 01:44 PM
Got the gellato tool. But im unsure of how to get my original file off to send it to him...helppp
Pro steve remap...
31-10-2013, 07:27 PM
Its on his website isnt it? Im pretty sure you only press read then save or something like that, been a while since i done one!
01-11-2013, 10:18 AM
done mine the other night, make sure you have all the cable drivers installed firstly.
then head to the car, cable in, program loaded and give it a couple of seconds to settle and load fully, key in and onto second turn, then hit ecu data i think it is, then once its done you click read data i think and save the file somewhere, one thats done turn the car off and then back on again to check everything over.
01-11-2013, 10:20 AM
Did you have a red border around your screen on the software?
trying to remember off hand, i think i did!
is it not reading the data? I got the drivers, and the instruction file off pro steves website as the seller provided me with sweet FA.. Instruction Guide - http://www.hdi-tuning.co.uk/downloads/Ga...20LTD.docx Drivers/Software - http://www.hdi-tuning.co.uk/downloads/gal_1260.zip
01-11-2013, 10:30 AM
When you get the chance can you have a look please? Ive done all of the above. But I get this thing about turn the dashboard off for 10seconds just on reading the ecu data
01-11-2013, 10:40 AM
you get that after you read the file matey? im in uni atm and have to borrow a laptop to do the process (needs XP) so im afraid i wont be able to until im remapping the car, which will probably be a weeks time.
according to that guide you go to; 'Select ECU data, then read data, you can then name and save the file.' whenever you read the data and chose the place to save the file (306orig is what i named mine) then it goes through the process and after that you have to turn the ignition off for ten seconds. where are you saving the file to? have you checked if its there, as it should be after what you've described.
01-11-2013, 10:44 AM
Doesn't it work on window 8?
And the Ecu data bit it goes wrong from there. Dont even get to do the file naming process
01-11-2013, 10:58 AM
no buddy you need to use windows XP. There arnt drivers for the cable/software compatible with anything onwards of XP, hence me having to borrow a laptop.
You need XP and a good laptop that wont crash, when u insert the cable and it asks you to install drivers, you have to direct the driver to the folder in the downloaded files called something along the lines of 'xp 2k drivers'
01-11-2013, 11:12 AM
I've remapped using a Galletto and windows 8.....
01-11-2013, 11:17 AM
Realllyyy? Dafuq am I using xp for then, was certain it would only work on xp.. uh oh
01-11-2013, 11:21 AM
Lol, plenty of people said it wouldn't work on win8.... I just uploaded it and it worked straight away. Might have done it in compatibility mode or something though, can't remember.
01-11-2013, 11:51 AM
(01-11-2013, 11:21 AM)Toms306 Wrote: Lol, plenty of people said it wouldn't work on win8.... I just uploaded it and it worked straight away. Might have done it in compatibility mode or something though, can't remember. I didn't work with win8 for me either. I had to use win7 instead.
01-11-2013, 11:52 AM
I have win 7 but was led to believe it was only suitable for xp, will try my 7 laptop later and see
01-11-2013, 12:10 PM
Ill have to try again later on mums laptop giving me a reaaaal headache ordered a Wpps cable too now
01-11-2013, 12:29 PM
I firstly got a kwp2000+ but it didnt work so ended up with the galletto.
01-11-2013, 12:40 PM
I've uploaded several maps on win7 with galletto and never had any issues.
pro steve? | Jimbo | 10 | 3,118 |
15-05-2015, 12:14 PM Last Post: Frosty |
