Threads: 289
92
Car Model/Spec: Phase 17 R26
Did you fix your issue that was causing your high ping?
Threads: 343
15
Given 3 thank(s) in 3 post(s)
Do you have a decent'ish phone, down load the photobucket app and upload them that way, i only just found out about it makes my life so much easier. Basically do everything from my phone now as the laptop can be soooooo slow some times
Threads: 36
Car Model/Spec: PH2 Dturbo
Is it any website that you can't upload to?
Try Speedtest.net and see when you do the speed test if it will actually upload data.
Lol don't think I've ever seen Talktalk return good speeds!
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
Campus uni speeds were nuts. 300MB / 150 MB DL/UL.
Threads: 289
92
/inb4foobypostsgigabitspeeds
There's obviously something wrong with your connection if you're not able to upload files to lots of different sites. Have you tried using a different browser?
Threads: 289
92
Remember Google doesn't run on a single server, it sends you query to a number of servers which are best suited for you geographically and in terms of connection speed (among other factors), then the one which displays the page is the one that returned a result the fastest. Just looks like it wasn't able to connect to those other servers and returned a result from another server. If you tried with the forum server then it would yield a different result.
