dash light problems
dash light problems
Hi
Hope someone can help, I have had my 306 for a while
And have a few dash lights need help sorting.
The handbrake light sometimes comes on and stays on (when handbrake off)
But if you turn the car of and on the light goes again.
Also I have the abs light on, I have read about testing sensors, what else
Can I also test if they are all ok.
and finally the engine management light is on, it came on after doing clutch
Cable when leaving the maf unplugged, would this cause it, as thought it
Would go out after while or can I leave battery unplugged or is it a plug in
And clear code jobbie
Thanks
Handbrake light I was told is a sign of either a faulty pad wear sensor or your pads really are low.
MAF disconnected would cause engine management light to come on. You'll need an OBD reader to clear the code.
  306 cab dash teething problems NETSPACE 1 1,013 23-05-2021, 10:32 AM
Last Post: Mighty306
  Flashing battery light. NEW PROBLEMS Matt 25 5,555 11-09-2016, 06:57 AM
Last Post: C2K
  Battery light problems :( ArbGarry 20 3,550 07-04-2014, 07:49 PM
Last Post: Kezzieboy
