13-08-2013, 09:04 PM
hiya, does anyone know the max torque or bhp figures a valeo 180mm clutch can hold.
thanks in advance
thanks in advance
180mm clutch
thanks in advance
14-08-2013, 06:00 AM
iirc they start to give when they reach about 220bhp and / or 200lbft, it'll all be relative though, they may 'last' past those figures, but not for long, your best bet if you fancy running a little more power is to fit one of the 200mm clutches from a saxo/106, a couple of the people on the AXOC run standard 200mm on their turbo's, albeit the peeps who run 300+bhp use paddle / ceramic clutches
hope this helps,
Project: Formula Peugeot
14-08-2013, 04:14 PM
Approximately 200-220lb/ft static, but wear at that will be very high, and you'll probably find the clutch overheats and slips on full bore gearchanges and launches. 160-170lbft is more reasonable if you want it to last.
14-08-2013, 04:51 PM
mine slips at 190lb/ft under full throttle acceleration when it's hot. holds ok otherwise
14-08-2013, 06:59 PM
cheers for the replys guys, ill probs have to upgrade to a 200mm clutch then
