Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Given 30 thank(s) in 30 post(s)
Just after a few ideas how i can my air filter pipping and filter. I have seen that a few people have done it different ways and i was just wanting to know what is the recommend way. So whats my options?
And before anyone says it i dont really what to go de filtered
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 31 thank(s) in 31 post(s)
2 meters of flexi pipe should do the trick, behind the engine and over the gearbox
http://www.ebay.co.uk/itm/Flexible-Air-D...4d08602ebd
Threads: 110
20
Ok cheers so do you think have a 90deg bend off the turbo and the onto the flexi pipe?
Also would i want 1 or 2 ply?
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
I still need to get some of this...!
>_<
TD04 inlet size anyone?
Threads: 374
38
Car Model/Spec: GTI 6
I had a nice setup before on my old DT before I defiltered it. Had a U bend from the turbo, with a 90* bend to bring the filter to the front of the car
I'll try find some pics of you want?
Threads: 110
20
(15-06-2013, 06:34 AM)ginge191 Wrote: I had a nice setup before on my old DT before I defiltered it. Had a U bend from the turbo, with a 90* bend to bring the filter to the front of the car
Yeah pics would be ideal if you can find some cheers
Threads: 127
33
You don't need any bends as this stuff if flexible
Straight off the turbo and then wherever you want
Threads: 110
20
Any luck with some pics bud?
Threads: 171
46
Given 1 thank(s) in 1 post(s)
Threads: 33
2
Car Model/Spec: 306 D-turbo/306 Rallye
Still have the standard tmic pipe on mine, works fine but occasionally it causes a bit of vibration through the pedals
Blaze '6 and Blaze D-turbo!
Threads: 143
10
Car Model/Spec: Ph3 XUD
Given 8 thank(s) in 8 post(s)
(23-06-2013, 08:50 AM)Mitch Wrote: Still have the standard tmic pipe on mine, works fine but occasionally it causes a bit of vibration through the pedals
Mondeo ST intercooler?
Threads: 9
Car Model/Spec: d turbo xud
(23-06-2013, 08:50 AM)Mitch Wrote: Still have the standard tmic pipe on mine, works fine but occasionally it causes a bit of vibration through the pedals thats a really tidy setup fmic looks so oem
Threads: 33
2
cheers guys, i think its off a mondeo or a transit? jenk made the kit, sold it to chris90 and now its ended up with me! thats the reason why i got it really, like things to be oem!
Threads: 9
so are u not running a fan or is it mounted behind rad
Threads: 33
2
I don't have one, car never really goes above 80, if it does, heater on flat out an windows down
Threads: 132
4
Car Model/Spec: 305 and 306 HDi's
Given 6 thank(s) in 6 post(s)
(23-06-2013, 11:39 AM)Mitch Wrote: I don't have one, car never really goes above 80, if it does, heater on flat out an windows down
Can't be running much boost then...
Threads: 122
9
Car Model/Spec: Kingfisher Ph1 Dturbo S
(23-06-2013, 08:18 PM)Sambarker Wrote: (23-06-2013, 11:39 AM)Mitch Wrote: I don't have one, car never really goes above 80, if it does, heater on flat out an windows down
Clearly not. Asking for trouble not running a fan on a boosted xud
Threads: 198
135
(23-06-2013, 08:57 PM)Jimbo Wrote: (23-06-2013, 08:18 PM)Sambarker Wrote: (23-06-2013, 11:39 AM)Mitch Wrote: I don't have one, car never really goes above 80, if it does, heater on flat out an windows down
Not necessarily, depends what turbo, what fuelling, how it's driven.. I run manual fans and don't need them unless sat in traffic on a hot day. When you're doing over 30mph you don't need the fans anyway.
Threads: 122
9
But theres always gonna be a time your sat in traffic. For the effort of fitting the fmic just wack a fan and switch in
Threads: 33
2
21 psi on a T2, previously 28 psi on a k14, the car doesn't get hot, no matter how much death it's given, gets to 80 and that's it, so I don't really see the need for the fan?
Threads: 110
20
I got the intercooler pipes all fitted today and i dont know where to have an air filter and how to run the pipes. Anyone got any ideas?
Threads: 226
24
Car Model/Spec: A3 TDi
^^^ love that! Looks like such a clean set up!
Threads: 541
124
That is an awesome looking set up but the top pipe is gonna hit the bonnet.
Id run a pipe above the right hand boost pipe and then out to the air filrer or even have it behind the battery with some ducting.
Threads: 110
20
(07-07-2013, 09:30 PM)Dum-Dum Wrote: That is an awesome looking set up but the top pipe is gonna hit the bonnet.
Yeah i think your right. I have cut a bit off the pump to get the pipe down a bit but i will have to have a think and sort something out.
Have to have more of a think/look about the air filter but i was thinking about trying to get it run down the right hand side
(07-07-2013, 09:06 PM)Tom Wrote: ^^^ love that! Looks like such a clean set up!
Cheers but credit to sam as i brought it off him
Threads: 33
2
(07-07-2013, 08:59 PM)Frosty Wrote: I got the intercooler pipes all fitted today and i dont know where to have an air filter and how to run the pipes. Anyone got any ideas?
Have you thought about trying the tmic pipe? It's said to be restrictive but it's got to be better than hot and non filtered air surely?
Threads: 110
20
I have fort about it but i havent tried it and i think the intercooler pipes might be in the way. I will see how i get on before i try it
Threads: 110
20
I have decided to make the air filter pipe work out of the air ducting. Will be similar to what ricky had on his d turbo. I am now stuck on what air filter to use. I dont have a massive amout of room but now the size of the air filter make much difference?
Threads: 127
33
You still debating this lol?
Get it on You'll want as big an air filter as you can fit
Threads: 110
20
(12-07-2013, 10:34 PM)zx_volcane Wrote: You still debating this lol?
Yep lol. Hopefully get it sorted next week
Threads: 110
20
I think im going to ordered 2 metres of this just to try it and see how i get on
http://www.ebay.co.uk/itm/330651585086?v...102wt_1159
And as for an air filter think i might just go for a cone filter like this and see how it fits
http://www.ebay.co.uk/itm/290642212807?v...134wt_1159
