29-04-2013, 09:36 PM
Anyone got any experience in getting 3 door seats to fit a 5 door? Is it simple to swap the subframes or is it a complete nightmare?
3 door seats, 5 door car
29-04-2013, 09:39 PM
matt cheese is the man to talk to on this subject
![]() requiers welding though
29-04-2013, 09:40 PM
Doesn't sound promising, don't want to lose my phase 1 '6 seats
29-04-2013, 10:45 PM
blah this question is being asked like 3 times a week now D: The subframes are different so needs welding.
29-04-2013, 11:18 PM
doesn't require welding . . .but i did have to retrim drivers seat, as the subframe wouldn't bolt up to the drivers side but it did on the passenger side with some grinding, the seats are different between phase 1 and 2 i believe . .i'll help you more tomorrow, i'm gonna bed now . .
30-04-2013, 07:18 AM
Nearly a bolt in bolt out job. You've one bit to cut off on the 3rd seats, but then you can just bolt the 5dr subframe to it, but it will leave the whole seat sitting about an inch higher, which is a lot.
That's what I did first time round, however I think the 5dr reclining mechanism is stronger, never seen one get wobbly yet, and so I went back and retrimed my orginals. Again, simple enough job, just a bit of a balls with lots of wire clips. And if you're going from pov spec seats to dturbo or gti seats you'll also need to weld in bolster supports.
30-04-2013, 08:53 AM
(30-04-2013, 07:18 AM)Harky Wrote: Nearly a bolt in bolt out job. You've one bit to cut off on the 3rd seats, but then you can just bolt the 5dr subframe to it, but it will leave the whole seat sitting about an inch higher, which is a lot. you can't bolt the 5dr subframe to 3dr S16 drivers seat . . .i speak from experience, the others you probably can but as you say, it leaves the seat an inch higher, ok for passenger seat but no way would you want it on the driver's side, best to re-trim that one at the least . . ![]()
01-05-2013, 08:42 PM
Think I may leave it and just sell the seats.
Just hate leaf pattern..
02-05-2013, 01:48 AM
I put 5dr seats into a 3dr alright in a phase 2. Bolts to the floor in the 5dr both sides. But in the 3dr the outside bolts to the sides. just brought angle iron fron the oe runner out to to the sides. Sits an inch higher ( which does make a difference) but a lot comfier than my old seats.
Sealing interior door panel | Mighty306 | 4 | 1,935 |
25-11-2020, 10:58 AM Last Post: Mighty306 |
Rear passenger side door won't open | DonGonzo | 0 | 907 |
19-10-2020, 10:25 PM Last Post: DonGonzo |
5 door phase 3 interior parts for sale | Teeharv | 1 | 2,137 |
15-03-2019, 01:03 PM Last Post: Teeharv |
