29-01-2013, 02:55 PM
When your freeing these up is the spring meant to be loose? Falling from side to side? Or is there meant to be another spring to take up the slack? Thanks
Brake bias valve thingy
30-01-2013, 06:55 AM
The spring should only be loose when jacked up in my experience.
30-01-2013, 08:01 AM
(30-01-2013, 06:55 AM)puglove Wrote: The spring should only be loose when jacked up in my experience. ??? Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
30-01-2013, 08:57 AM
(30-01-2013, 08:01 AM)Grant Wrote:(30-01-2013, 06:55 AM)puglove Wrote: The spring should only be loose when jacked up in my experience. It's pretty clear.... When the cars on the ground, the spring should be under load. When jacked up, it shouldn't be. Simples.
30-01-2013, 10:23 AM
Yeah grant!!!!!! What niall said
rear brake bias replacement | zx_volcane | 3 | 1,920 |
10-10-2016, 04:49 PM Last Post: welshpug |
Brake pipe routing with manual bias valve | Lolben91 | 15 | 3,346 |
26-04-2015, 09:23 AM Last Post: adam b |
bypass brake load valve | blinkyeatu | 0 | 845 |
05-02-2015, 05:51 PM Last Post: blinkyeatu |
