	Threads: 374
38 Location: Isle of Wight
 Car Model/Spec: GTI 6
 Thanks: 8Given 16 thank(s) in 14 post(s)
		27-06-2012, 05:06 PM
(This post was last modified: 27-06-2012, 05:07 PM by ginge191.)
		Minor update, got an hour in the scrappy today, managed to get all head bolts out with a standard socket wrench; winning! erm, removed the water pipes, disconnected the rest of the plugs, cables and general useless crap surroudning the head, but for the life of me couldnt get the cambelt cover off to expose the cams/take the head up. Also, the exhaust had been previously CHOPPED so i dont even have to fiddle with the exhaust side of things!
Heading again tomorow to try and drop the engine at least, a pic from todays work; FML
 ![[Image: WedRK.jpg]](http://i.imgur.com/WedRK.jpg)
EDIT: Also, purchased (when i say purchased, provisonally bought, but now seeing the car up for sale) a recon'd GTI head, loom, unlocked ECU, gearbox and shafts from Sam on here - if it goes through, he WILL receive a cheeky banana .
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		Check your Facebook post ginger.
Just for you Ginge
 ![[Image: 18d57782.jpg]](http://i290.photobucket.com/albums/ll257/niallharper/18d57782.jpg)
Cylinders 1 and 2 have been honed. You can see where the rings were wrecked and the piston has been "slapping" against the cylinder. This isn't ideal however it's still smooth.
Cylinders 3 and 4 are how they were when I first removed the head. You can see some light scoring in the cylinders. Again, not ideal but honing should remove this.
 ![[Image: f9cef97b.jpg]](http://i290.photobucket.com/albums/ll257/niallharper/f9cef97b.jpg)
You can see there is permanent damage in the top inch of the bores. Nothing you can do about this unless you bore it and fit oversized pistons.
This won't cause a problem to running at all but it's a good history of the engine.
If you like, you can borrow my honing tool
	Threads: 374
		i SEE!
 awesome pics there. also, how much is this honing tool going to take away from the bores if any, or is a very light 'grit type' to take away the scoring?
		It's a very slight grit. I would compare it to 800 grit sandpaper. The idea is your trying to get a cross hatch effec (will try and get close up photos when we take the head off my old one) to control oil.
	Threads: 374
		Oh ok, i hear ya', yeh, this could be awesome  - OR niall, you could take a trip down, spend a few days when i sort out some conrods, and having a 'boaring/corod' weekend?
sort it nearer the time, but i think this block could be a good'n
		Ginge providing you provide me somewhere to sleep, I will come down and help ya. This engine will be epic but you just need to take time and do it properly. Get excited and rush it and it will run like shit. And that's when you get disheartened because it's not like it's a 10 minute job to rebuild it!
	Threads: 374
		 (27-06-2012, 09:16 PM)Niall Wrote:  Ginge providing you provide me somewhere to sleep, I will come down and help ya. This engine will be epic but you just need to take time and do it properly. Get excited and rush it and it will run like shit. And that's when you get disheartened because it's not like it's a 10 minute job to rebuild it!
...hence giving myself a YEAR to do it.
But yeh, i'll feed you, house you, sleep with you, you name it, i'll provide it
		Sweet. I've got a few fantasies I want to try out. Game?
 Give me a bit of notice and I'm happy to come and help ya. Will be in my element taking engines apart!
	Threads: 374
		 (27-06-2012, 09:20 PM)Niall Wrote:  Sweet. I've got a few fantasies I want to try out. Game?
yeh, game on! we can exchange fantasies and the such like and perhaps play a few games...
any way, yeh, with your experience on 1.8 dismantling, we'll get it done in a few days
	Threads: 5
4 Thanks: 0Given 0 thank(s) in 0 post(s)
		Could even have an iow meet with more than two cars :O
	Threads: 289
92 Location: London
 Car Model/Spec: Phase 17 R26
 Thanks: 0Given 1 thank(s) in 1 post(s)
		Can they fit more than 2 cars?
		 (27-06-2012, 09:44 PM)Scott Wrote:  Can they fit more than 2 cars?
Yeah easily. Just getting them there is the problem. Ever seen castaway?
	Threads: 374
		Stop hijacking this PLEASE..
but yeh, a mini-meet would be good, Tom, you'd make a great tea-lady, unless you decide to one day get your posh clothes dirty and learn something and chip in
	Threads: 5
		I'll learn something and chip in    if you need a spare pair of hands tomorrow morning, give me a text, free until work at half two.
	Threads: 374
		 (27-06-2012, 09:57 PM)thms182 Wrote:  I'll learn something and chip in  if you need a spare pair of hands tomorrow morning, give me a text, free until work at half two.
Come to cowes for 10am mate? i'll chuck you a text. Cheers!
	Threads: 374
		Keeping it alive - got back to the scrappy today to get the head off - had a bit of a PITA with the cambelt cover, but was the fault of myself not seeing a bolt at the back of the cover i missed..... ANYWAY... got the head off with just a standard wrench - who needs breaker bars - and someone had also cut the exhaust prior to me taking it so didnt need to touch that side of it! winning! ![[Image: IMG_1409.jpg]](http://i1071.photobucket.com/albums/u501/ginge191/IMG_1409.jpg)
Then found the HG is still re-usable! WINNING!!
 ![[Image: IMG_1407.jpg]](http://i1071.photobucket.com/albums/u501/ginge191/IMG_1407.jpg)
But unfortunately ended being unable to get the gearbox off - i got 3 bolts off the top of the box - the driver side shaft came out (just above the bottom engine mount), would this prevent the box coming off? i would have thought the box would still drop with it in that end?
Anyway, 3 bolts around the top of the box, and the only bolts in the bottom were on the sheeth to protect the fly. It seems to be stuck from the INSIDE? i dont want to have to take the box aswell as i dont want/need/afford it.
For the LOLS and a worthy tool
 ![[Image: IMG_1412.jpg]](http://i1071.photobucket.com/albums/u501/ginge191/IMG_1412.jpg)
	Threads: 5
		You forgot the sad picture where you cut your finger...
	Threads: 29
18 Location: Portsmouth
 Car Model/Spec: mx5 mk1 1.8
		 (28-06-2012, 12:47 PM)thms182 Wrote:  You forgot the sad picture where you cut your finger...
I would like to see this picture...
	Threads: 374
	Threads: 29
		 (28-06-2012, 01:08 PM)ginge191 Wrote:  http://i.imgur.com/dW6Rt.jpg?1
 ..it wouldnt stop bleeding
Haha, ANOTHER cut on your fingers... so clumsy.
	Threads: 448
51 Location: isle of wight
 Thanks: 17Given 18 thank(s) in 18 post(s)
		Your a massive girl ginge.
 Although good to see some progress being made
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg) TEAM CONROD SHITTING RALLYE!
	Threads: 374
		...cuts hurt, and the sight of blood makes me FAINT!
 lol i jokes, in al seriousness, i was worried of getting blood on the exposed engine... so was just pressing it until it stopped.
 Getting back there on saturday to get this out once and for all!
119 Location: Southampton
 Thanks: 13Given 106 thank(s) in 106 post(s)
		28-06-2012, 03:21 PM
(This post was last modified: 28-06-2012, 03:22 PM by Poodle.)
		Erm, sorry if i'm stating the blindingly obvious, but you have disconnected the clutch, right..?
	Threads: 374
		 (28-06-2012, 03:21 PM)Poodle Wrote:  Erm, sorry if i'm stating the blindingly obvious, but you have disconnected the clutch, right..?
...disconnecting the clutch? im sure when we did my dturbo, the clutch fork come off simultaneously as the box (if that makes sense.. i was assuming this XU engine would have the same principle. In all honesty, we had to leave by lunchtime, so only had about 10minutes before ACTUALLY trying to get the box off, spent most of the time disconnecting the entire loom (still there if anyone needs it), gear and clutch linkages.
	Threads: 5
		 (28-06-2012, 01:15 PM)MissTait_GTI6 Wrote:   (28-06-2012, 01:08 PM)ginge191 Wrote:  http://i.imgur.com/dW6Rt.jpg?1
Don't worry, I nursed him back to health. And it wasn't even awkward...
		Oh them bores look clean!
	Threads: 374
		 (28-06-2012, 04:44 PM)Niall Wrote:  Oh them bores look clean!
In all fairness, up close, that hatching you were saying about... Still visible. Slight surfac crap but should scrub up, what you reckon?
		When you go back, take a brillo pad with you and some 3in1 and give one a clean up and make sure it cleans up easily with no pitting. It's difficult to say with that photo.
	Threads: 71
4 Location: cornwall
 Car Model/Spec: 205 dt
		awesome project, none of this of the shelf kit stuff is what I like to see! would be keen to do similar to my 6 and keeping it low boost so run on standard internals, really not sure how much they can take reliably
![[Image: signiture.jpg]](https://lh4.googleusercontent.com/-7ORHe1luJy0/UIW7RcRdrGI/AAAAAAAABjE/n7i9b1goCYM/s500/signiture.jpg)  Midnightclub Wrote:All the cool kids have ph 2 Nile 6's!
		That's what i would have expected to happen too, but we had this issue when it came to taking apart the cabby engine.
