	Threads: 6
Car Model/Spec: le 'state
		Why cant I find a simple guide....either written in some jibberish or the diagram is for the main beam/ side lights.....and I need to know how to wire the dipped beam in.
Anyone have a complete diagram or clear written guide?
Its for P2/3 morettes, coming from H7 to H4....unless H7's can be wired in?
	Threads: 177
		Would it not be easier to look at and orignal ph2 headlight and copy the way it wire, or get scrap ones like i did and use the loom from them
	Threads: 6
		I thought p2 and p3 lights were the same up to the point if the lenses?
81
		I thought the wiring was exactly the same and you just needed the Phase 3 light stalk to make them work properly? Ive got some morettes which ive never got out the drawer since i got them. Ill have a go at some point!
	Threads: 177
		Ph2 uses H4 bulbs and ph3 uses H7 so the loom is slightly different
	Threads: 57
Car Model/Spec: 306 s16 406 v6 Saab 93 Ttid
	Given 3 thank(s) in 3 post(s)
		I just made jump wires from the original connector to the morette ones
