Threads: 105
Car Model/Spec: Stage 1 moonstone HDI
I'm a beginner with 306s and diesels, can anyone give me my options on making my 2.0 HDI better with acceleration? Ive read a little on taking the insides out of the cat and welding it back up but I'm not entirely sure.
Would a remap do much? Don't want a performance based car, just a little faster, practical Hdi
Thanks guys
Threads: 39
Car Model/Spec: 306 gti6
Best off getting a remap it really transforms the car and gives it the power it should have had standard tbh, also a decat goes nice with a remap
Threads: 105
So a remap doesn't stress the engine at all more than it should be? That's my only concern you see. Also do any negative effects come from a remap at all?
Threads: 252
7
Only if you get a cheap shit map. Get a proper map from someone that knows what there doing, Prosteve or Whippy and you really can't go wrong
Tuning box's are also not worth there weight in dogshit
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 39
No not really the engine is more than capable of a remap and the only negative is that if you're clutch is pretty worn out then it will probably slip (might bed back in tho) but if its fine then it should handle the power nicley,
I had to change the clutch on mine but my car is an ex learner car so the clutch was pretty worn anyway
Threads: 171
46
The engines are capable of double standard power
No one iirc has had reliability issues pushing 150-160on a stage 2
Threads: 105
So what bhp am I looking at from a remap considering my car is 90bhp?
Thanks
Threads: 82
27
around 120-130bhp and around 190-220lbft
Where are you based?
Threads: 105
I'm Wirral, near Liverpool and north wales
Threads: 171
46
I think Mr whippy is up north. Leeds iirc?
Well worth the trip
Threads: 105
I think I will go to whippy, closer than anyone. Has anyone here had a remap?
Threads: 171
46
A lot of people have
Its definatly worth it :-)
Threads: 105
Again guys thanks for your help! I'll get it booked in a few weeks time or so!
How long does a remap take them?
Threads: 39
Got my remap off whippy top bloke and top work, well worth the trip
Threads: 105
I've heard after a remap the clutch can slip, why is this?
Threads: 131
6
Car Model/Spec: MX5
aaron_one Wrote:I've heard after a remap the clutch can slip, why is this?
because its producing more torque. the clutch is only designed for the standard torque so when you up it, it will slip
Threads: 105
Does this not annoy anyone lol
Threads: 171
46
Ben Jay Wrote:aaron_one Wrote:I've heard after a remap the clutch can slip, why is this?
because its producing more torque. the clutch is only designed for the standard torque so when you up it, it will slip Don't listen to Ben
A hdi on a stage 1 remap will take all the torque
Its only when you look at stage 2 and fmic it will start to slip and even then not too bad!
So yeah it will be fine
Threads: 105
So it wouldn't even slip over time on a stage one?
Threads: 171
46
No. Well it shouldn't and if it does then your clutch is very worn and would start slipping VERY soon
Threads: 252
7
I have a Whippy stage 1 Map running 128.2 bhp and 213lbs/ft and my clutch was fine for abit, slipped and is now fine again.
It really is a different car, and thats on 170k+
Blaze 1.6 Dead
Threads: 105
Very tempted to go for it now!
Threads: 171
46
Threads: 39
Threads: 105
LMAO.
out of curiosity what film is that?
I've contacted Dave at whippy and he said he can work around the clutch needs etc, I'm booking it in the next week or so!
Threads: 39
Its from the film dodgeball
Naturally if you drive it hard and abuse the clutch - fast gearchanges and not allowing the clutch to engage before getting back on the power will really wear out clutches...
With increased power/torque, you will eventually wear out the clutch.... Naturally you've got more power going through the driveline, don't be surprised if teh clutch doesn't last quite as long as if it was 100% standard - if driven sensibly it should last for at least 80% of the time a standard one will (standard it'll last around 100-120k miles depending on driving style) so expect around 80k out of a clutch...
Drive it hard and abuse the clutch, you can expect that figure to drop very quickly!
For example - my clutch which is the older XUD9 clutch dealing with around 300-320lb.ft torque has lasted me only 26k miles, but then I drive it hard and do abuse the clutch... I consider that still to be a pretty good lifetime for double the standard torque figure.
Threads: 3
Car Model/Spec: 306 HDi D Turbo
Great explanation Ruan.
It's kinda hard to explain some times without getting too technical and then not making the point, but I think that pretty much sums it up
I know that a new LuK clutch will take about 240-260lbft if you are sensible with it, so they have a fairly good torque load capability. The Valeo ones might be even better.
I know a few people running FMIC with new OEM clutches at about 250lbft without any problems if they treat the clutch sensibly, and have been going years.
As Ruan says, if it slips with just a stage 1 tune chances are it was well on it's way to needing changing any way!
I was unlucky with my HDi. It was FPSH one owner from new and it slipped as standard about 2 weeks after I bought it, but after that I ran endless remaps, 0-60 runs, 1/4m runs, 1st > 2nd > 3rd runs with throttle flat during shifts, loads of remap testing and all sorts, and it was totally solid until I fitted my FMIC mapping at which point it wasn't so happy, but still held on well!
In over 100 Stage 1 HDi's I've only seen two that slipped so much that people needed new clutches. The rest just gripped fine.
HDIkyle Wrote:I have a Whippy stage 1 Map running 128.2 bhp and 213lbs/ft and my clutch was fine for abit, slipped and is now fine again.
Do you have a dyno plot for that? I'm interested in the wheels figures and stuff too if you got them.
Dave
Threads: 105
Great thanks for the explanations.
Right, any other good ways to increase acceleration?
Threads: 183
20
Strikeforce Wrote:Its from the film dodgeball  starskey and hutch actually.
Currently I've only decatted mine but really want it remapping.
But with decat I noticed a little difference. But before you do anything always give it a good service. Helps loads.
Mr whippy will soon be pming you. When funds allow I want my hdi remapping. What figures can you get from stage 1 and what price? Also where you from If I can travel to you maybe cheaper than buying kwp.
