Threads: 25
I currently have a set of 206 nimrods-ET28-(not yet fitted)
But im not too sure what setup to go for without causing extra wear on ball joints bushes and bearings?
1)206 nimrods with 10mm spacer-is this the correct thickness of spacer?
2)406 nimrods no spacers??
Advice please
Thanks
Threads: 448
51
206 ones use 13mm to be correct. Make sure they are hubcentric though. I ran hubcentrics with mine and they were fine no excess wear on joints or anything
Threads: 25
im getting 10mm hubcentrics.
but im intersted to know how come you ran 13mm?
im going from my standard d turbo alloys to nimrods:
5.5j x 14-ET24 to 6.5j x 16-ET28
How can i work out the exact thickness of spacer required to ensure that the nimrods sit in the same position as my original alloys?
Thanks
Threads: 25
I was gunna go for the 13mm but i could not get extended wheel bolts to match the 13mm additional thickness
Threads: 198
135
Ideally you want as big a spacer as you can get hold of. And smaller tyres.
Lower it.
Threads: 25
thanks for the clicky donator
Which value on the 'table' shall i use for the spacer thickness?
Thanks
Threads: 25
So 10mm should be ok as they give et18?
thanks
Threads: 25
Just been told by a guy at the motor factors that extended wheel bolts are a danger to life!!
Wtf is he being serious
Comments Guys
Thanks
Threads: 53
6
Car Model/Spec: XRdt.
They are only a danger if you buy the wrong ones
Threads: 25
Is it wrong to use taper to flat seat conversion washers??
Where can i get some flat seated extended wheel bolts?
Thanks
Threads: 289
92
Car Model/Spec: Phase 17 R26
I'm not sure on it but personally wouldn't be comfortable using conversion washers with extended bolts. I'd get bolts which are the correct fit as there'll be enough additional strain on them as a result of being longer.
As said though, there's no issue with buying longer bolts if they're the correct fit. I'm not sure how expensive they are anymore but you could get some 10mm or 15mm stud conversion kits.
Threads: 198
135
If you're running spacers, stud and nut conversions are a necessity imo. Make life SOOO much easier.
Threads: 25
I found some flat seated extended bolts from a sole uk company which gets them in from germany
Will put some pics up when i get them
