205 GTi 2.1 TD - XUD11T
Hi Friends.
A long personal project, started in 2009, lots of work, lots of nights. But it runs....From France
2.1 TD 12s Forged, with GTB2060VKLR MFS 62mm
Custom 4 in 1 exhaust manifold and intake manifold
First version OEM conrods broke
NOW CUSTOM 2.1 TD FORGED CONRODS
Diesel parts designer:
-HDi/1.9td and 2.1 XUD11T forged HBeam conrods available in stock
-Custom ARP Head Studs kit available for HDi/1.9Td and 2.1 XUD11T
-Aluminium damper pulley for Hdi/Xud11T
-MFS prechamber for XUD
Ask for delivery
Welcome along. Well done on braking a rod. I don't think anyone in the UK has amanged that yet
bienvenue my friend, i'll bet that goes like shit off a shovel! Big Grin
Excellent work.
Good to see the XUD11 in a 205, not seen that before.
How does it handle with the big engine?
                                             [Image: 2ljm03k.jpg]
        I Don't Have A 306.
Smile
(07-06-2018, 05:48 PM)Danny Wideboy Wrote: Excellent work.
This sort of swap is very famous in France!
The torque is crazy. And handle very high but the setup is not ready for the full power.
I have some adjustements with the front frame. And for the moment the turbo is not managed by my electronic boost controller. But engine is very powerful yet Smile
Ask for delivery
Awesome Big Grin Did you fit a Bosch pump or keep the Lucas?
Yes of course Bosch is the best 494 9mm original with mods inside.
I m making a new 11mm for the next stage
Ask for delivery
My exhaust manifold
I prefer to pass the intake pipes under the engine, for more space over
The flywheel is lightened -2.2kg
Ask for delivery
I designed this new aluminium pulley for xud11T and 2.0 HDi, now it's 520gr against 2.2kg before.
Available for who wants the same.
Ask for delivery
Looks good!!!
I'd strongly advise fitting a later 206 or 406 HDi alternator with that pulley if you can - it will prevent damage to the belt, idler and dampener. With the engine rotating assembly so light, the inertia in the heavy alternator can cause damage to the belt. That's why HDis have a rubber pulley or a freewheeling clutched alternator instead.
Ok Ruan. Thanks for the advice. But are you talking about the timing belt or the alternator belt? Not sure to understand....
Ask for delivery
He means your alternator belt.
The alternator will become too heavy to turn because the drive pulley is so lightweight, the belt will slip/vibrate etc and become damaged.
Newer alternator from a 406 HDi has a freewheel alternator. It has a "clutch" on it which operates one way. a bit like a bicycle wheel.
So the risk is only to brake the alternator belt.
I run like that during more than 5000km before with my first R.I.P 2.1td (standard conrods broken).
And the belt is still alive.
Do you have picture of the 406 hdi alternator?
Ask for delivery
(21-07-2018, 10:20 PM)Biggen Wrote: So the risk is only to brake the alternator belt.
The risk is to the belt, alternator and the dampener - it will be made much worse with the lighter pulley. You can usually tell the clutched, freewheeling alternators as they have a cap over the pulley like so:
[Image: CA1553%20(4)-400x400.jpg]
It will also help the engine's response as the the alternator can spin down freely, so the engine revs fall faster, meaning faster gear changes etc.
Thanks a lot for this information, i have never heard about this new technogy. I know only the old engines...hahaha
But I will test like that. I have never got problems before. I will let you know.
The revs already fall faster with 5kg less on the crankshaft....
Ask for delivery
Users browsing this thread: 23 Guest(s)
