Threads: 67
Car Model/Spec: 306 Sedan - Ph1 Dturbo
Given 6 thank(s) in 6 post(s)
Not sure where to stick this.
Miss's has not long got herself a little 208 1.4 hdi and already looking at mods (im poss a bad influence...).
Anyways just curious whats possible with these engines. Seen a map will take it from 67bhp to roughly 90bhp but was just wondering what gains are possible beyond that. Not wanting to swap the engine and really just after off the mark poke.
![[Image: ec6c8c6f944e630702b39a1605769297.jpg]](https://uploads.tapatalk-cdn.com/20170217/ec6c8c6f944e630702b39a1605769297.jpg)
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
81
Just a remap is probably best. Its never going to be the fastest and a remap will easily be the best bang per buck.
Threads: 82
27
Think the turbo is right on the front of the block like the 1.6's so if you're brave enough you could swap that out for a bigger unit and map to suit, maybe one off the 1.6's if they're actually bigger
Threads: 67
(17-02-2017, 11:45 AM)Midnightclub Wrote: Think the turbo is right on the front of the block like the 1.6's so if you're brave enough you could swap that out for a bigger unit and map to suit, maybe one off the 1.6's if they're actually bigger Yeah the turbo looks seriously easy to change. Not like trying to force a gt20 down the back of my 2.0 [FACE WITH TEARS OF JOY] had though of recycling my gt15 into it. Turbos so small!
All the sensors in the exhaust kinda worry me as never seen so many.
Any ideas on how strong the blocks are or limitations in fueling? Struggerling to find any info.
As said not after top end. Just want it abit more nippy for a giggle
Justin_306DTurbo
Threads: 82
27
No idea honestly, doesn't seem to be many people playing with the 1.4's. BIG power seen on the 1.6's though, you can buy hybrids off the shelf good for 280hp iirc. Tbf just a stage 1 should really make it come to life, if you really wanna play with one probably better off getting something cheaper/older with the 1.6 in it as there's so many more bits and info available
Threads: 67
(17-02-2017, 11:55 AM)Midnightclub Wrote: No idea honestly, doesn't seem to be many people playing with the 1.4's. BIG power seen on the 1.6's though, you can buy hybrids off the shelf good for 280hp iirc. Tbf just a stage 1 should really make it come to life, if you really wanna play with one probably better off getting something cheaper/older with the 1.6 in it as there's so many more bits and info available Yeah ive seen some of those mad 1.6 builds and seems alot more potential then xuds and hdi 2.0. Kinda makes you wonder why people dont fit them in 306's...
Fair one. They didnt exactly seem a common engine by pug anyway. Wouldnt mind at least getting it mapped up and dpf gutted out
Justin_306DTurbo
Threads: 82
27
I think a lot of people get put off the 1.6's due to the turbo failure issues.. most of those are caused by poor oil and/or not changing the inline filter to the turbos so it gets starved of oil. Would quite like to see someone put one in a 306 though, imagine it'd be lighter than the 2.0 but it's probably a bit more difficult to sort out electrically
Threads: 67
Could make a pretty cool project for someone
Justin_306DTurbo
Threads: 67
Just picked up some steels for banding [GRINNING FACE WITH SMILING EYES] couldnt turn them down for £25 ![[Image: 88d3b56ebe015b27a31e52d1aa991ff3.jpg]](https://uploads.tapatalk-cdn.com/20170221/88d3b56ebe015b27a31e52d1aa991ff3.jpg) hopefully have the funds soon to get them done.
Got 3 spare 106 rallye center caps for them already. Just gotta source a 4th. So slowly getting there
Justin_306DTurbo
Your gt15 probably be a downgrade.
Remap it, enjoy it. Then be ready for turbo and injector repair bills.
Threads: 67
(21-02-2017, 05:23 PM)Piggy Wrote: Your gt15 probably be a downgrade.
Remap it, enjoy it. Then be ready for turbo and injector repair bills. Turbos so diddy tho! Guessing its alot more efficent then the old tech then.
Injectors and turbo known for being weak?
Justin_306DTurbo
Threads: 19
mines still pulling well after HDi Tuning did their magic. rolled out 110hp (ATF) and 170lbft
Threads: 67
(21-02-2017, 06:44 PM)mr_fish Wrote: mines still pulling well after HDi Tuning did their magic. rolled out 110hp (ATF) and 170lbft thats hopefull news! Had been reading that most people seem to hit 90bhp and thats it.
What sorta spec to get that power as would love to push double stock if poss
Justin_306DTurbo
Threads: 19
(21-02-2017, 07:00 PM)dr_jekyll Wrote: (21-02-2017, 06:44 PM)mr_fish Wrote: mines still pulling well after HDi Tuning did their magic. rolled out 110hp (ATF) and 170lbft thats hopefull news! Had been reading that most people seem to hit 90bhp and thats it.
I swapped the KP35 out for one that looks to be similar to what is on your one there. TD03 or TF03 I think. I took mine off a 90bhp 1.6 Focus.
Clutch did not like it at all. only a 200mm one in the 206 so strapped a 1.6hdi gearbox on with a bigger fly and clutch. Hopefully you'll already have a 225mm (or whatever it is - been a while since I did it) flywheel in the car as that'll cope with the torque.
Think Steve said rail pressure was coming up to its limit and then shortly followed by the injectors.
I never was going for all out power, just something to make it a bit more pokey, which it drives spot on now.
Threads: 67
23-02-2017, 10:34 AM
(This post was last modified: 23-02-2017, 10:44 AM by dr_jekyll.)
(23-02-2017, 09:55 AM)mr_fish Wrote: (21-02-2017, 07:00 PM)dr_jekyll Wrote: (21-02-2017, 06:44 PM)mr_fish Wrote: mines still pulling well after HDi Tuning did their magic. rolled out 110hp (ATF) and 170lbft thats hopefull news! Had been reading that most people seem to hit 90bhp and thats it.
I never was going for all out power, just something to make it a bit more pokey, which it drives spot on now. Spot on! Helpful bit of info  least we now know our options
Just trying to find clutch info and managed to find this ???
Mildy confused. Some sites say its the same as the 206 clutch, others say its 240mm..
Gotta pop into pug later so gonna see what info they can give me on her
Justin_306DTurbo
Threads: 4
Car Model/Spec: 306 HDi DW10
Country:
Dr. Jekyll check this 1.4 hdi from Turkey I think, in the comments of some of his videos he says the setup...
It's something like:
2.0 hdi nozzles
Head ported and polished
custom camshaft
hybrid turbo with intake of gt2556v and exhaust of gt15 2.3 bar stable
remap
exahust
etc.
Impressive mate!!
___________
Luís
Threads: 67
19-03-2017, 08:31 PM
(This post was last modified: 19-03-2017, 08:47 PM by dr_jekyll.)
(19-03-2017, 12:12 AM)loli_04 Wrote: Dr. Jekyll check this 1.4 hdi from Turkey I think, in the comments of some of his videos he says the setup...
2.0 hdi nozzles
custom camshaft
remap
exahust
etc.
Impressive mate!!
___________
Luís Cheers! All works kinda stopped atm as my own stage 3 hdi (306) just crapped out the injectors and began fitting an oil cooler ![[Image: d8b6649b069ea9ee370ac69bb74fdcb9.jpg]](https://uploads.tapatalk-cdn.com/20170319/d8b6649b069ea9ee370ac69bb74fdcb9.jpg) on the upside i harvest the stronger 076 injectors from local scrap yards so have a fair few spare lol.
Unfortunatley some knobs keyed the 208 tho. Looking at getting it plastidipped but this is only when gunds are free later. We more set on modding it first then sorting the paint
Have you got the link fella???
Justin_306DTurbo
Threads: 4
6
Given 7 thank(s) in 7 post(s)
On a 63 plate you're going to be on an EDC17 Tri core ECU surely?
It's a different turbo to the older 1.4 too, does look very tiny.
Haven't played with one of these yet, but I've done a lot on my DS3 with EDC17, should be very similar.
I imagine it would be good for a safe 90 BHP quite easily, the 1.4 engines really aren't that popular for remaps because most people buy them to drive slowly and save fuel etc, so I doubt there are many of the new 1.4s that have been pushed past a normal stage 1.
Threads: 67
(20-03-2017, 06:06 AM)pro_steve Wrote: On a 63 plate you're going to be on an EDC17 Tri core ECU surely?
I imagine it would be good for a safe 90 BHP quite easily, the 1.4 engines really aren't that popular for remaps because most people buy them to drive slowly and save fuel etc, so I doubt there are many of the new 1.4s that have been pushed past a normal stage 1. Is this somthing you could do in the future? Also need to contact you for a map on my 306 stage 3 hdi as would prefer to run your map after seeing the results on a friends. This will have yo be in the future tho when money isnt so tight
Justin_306DTurbo
Threads: 4
6
Yes it shouldn't be too complicated to do the 1.4 if it uses the same ECU as the 1.6. Have a look and drop me an email when you're ready for it.
And for the stage 3 map, get a read of the ECU and send it over. If you've not already got it I recommend the 1.6 FPS part No. 1920GW, and something like the GT2052S is a good turbo. I can also calibrate in the larger MAF from the 2.2 136 HDI if you've fitted larger pipe work.
Threads: 67
(21-03-2017, 11:51 PM)pro_steve Wrote: Yes it shouldn't be too complicated to do the 1.4 if it uses the same ECU as the 1.6. Have a look and drop me an email when you're ready for it.
And for the stage 3 map, get a read of the ECU and send it over. If you've not already got it I recommend the 1.6 FPS part No. 1920GW, and something like the GT2052S is a good turbo. I can also calibrate in the larger MAF from the 2.2 136 HDI if you've fitted larger pipe work. Sounds good to me fella. Will have to email you when i have the money then. The 306 is already sat on
- 3" intercooler
- cg paddle clutch
- 1.6 fps
- k&n with heat shield and direct cold feed (not a micky mouse setup)
- gt2052s
- full stainless straight through 2.5" turbo back
- egr delete
- mbc
- mocal thermostatic 16 row oil cooler
- r70
And probably some more bits ive forgotten
What could i expect from it?
Justin_306DTurbo
Threads: 4
6
These usually come out around the 180 bhp mark if you do everything properly and the engine is in good condition.
Drop me an email, I don't always remember to come on here.
Threads: 4
Country:
(19-03-2017, 08:31 PM)dr_jekyll Wrote: (19-03-2017, 12:12 AM)loli_04 Wrote: Dr. Jekyll check this 1.4 hdi from Turkey I think, in the comments of some of his videos he says the setup...
2.0 hdi nozzles
custom camshaft
remap
exahust
etc.
Impressive mate!!
___________
Luís Cheers! All works kinda stopped atm as my own stage 3 hdi (306) just crapped out the injectors and began fitting an oil cooler on the upside i harvest the stronger 076 injectors from local scrap yards so have a fair few spare lol.
Oh ok I see, is like me  Mine is at garage atm and beggining to unmount the engine to clean/repair/prepare, but need to find some info's about 2 or 3 things though... If you can help me or steve, please i'm all ears!
So: What oil cooler and plate should I look for?
What diesel cooler should I look for?
How should I wire the FPRS? (mine have 3 wires all green!)
It's a stage 3 project looking for about 190hp and arround 340 lb/ft.
Last thing I'll gonna do is to fit HP pump (probably CP1S3/ R75/10-1S, if I can find one, because is quite dificult get one in right conditions and I don't know how it will be to map  )
So specs that I'm thinking about are:
Garrett Gt1852v
Intercooler 51mm (original) from a renaut dci (740mm x 200mm x 40mm), IC pipping 57mm
Downpipe 60mm + full 63,5 mm stainles steal exhuast system + 63mm stainless steal final backbox
1.6 HDi FPRS
Oil cooler with bigger lines (aimming for 6L of oil)
Diesel cooler and bigger fuel lines (12mm)
Upgraded lift pump (APS or Walbro?)
So please help me to reach PUGFEST with my project already donee! (and returning back!!!) Me and my wife are thinking about going there!
I also need to find out a mapper who send me the map to portugal with enabled boost controller etc... And that explain me all I need to do to get the things done properly!!
Cheers
___________
Luis
