Threads: 2
Car Model/Spec: 306 1.9 D-turbo
Country:
Ph2 (98) d turbo.. No boost whatsoever. I have already changed all filters, blanked egr, checked for leaks - none found and no improvement.
Is there anything else I should be checking? Hoping there's an easy fix.. Worse than driving an NAD!
Threads: 82
27
Has the plastic inlet tubing collapsed? (check the inlet piping behind the inlet manifold)
Threads: 90
54
Have you removed boost hose from left side of intercooler and revved engine up to see if there is actually any boost at all?
Threads: 14
7
Given 5 thank(s) in 5 post(s)
Wastegate arm dropped off or something?
Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Given 30 thank(s) in 30 post(s)
Where abouts you to in devon?
