26-05-2016, 07:27 AM
Fit oil cooler so can stay out longer on track / reduce risk of fking the engine - Highly doubt it'll get done now as really could do with a second pair of hands
Fit thermal intake gasket without a vacuum leak
Sort out front tyre as it's taken some abuse - - ordered a part worn continental to tide me over
Gearbox oil - Still time but not sure if I should
Fix abs sensor issue - removed cable tie, drilled out and replaced the broken bolt then sprayed wd40 on it before giving a wipe over and now seems fine...so will say its fixed
Fit MG TF steering wheel
Fit rear anti roll bar
New pads up front - ordered but not yet arrived
![[Image: mcetg0.png]](http://i57.tinypic.com/mcetg0.png)
