08-05-2016, 12:29 PM
Would any one be able to take a picture of the oil feed in regards to the manifold , just trying to figure out if the hdi oil feed pipe will fit
Cheers
Cheers
Hdi oil feed on turbo can any one grab a pic
Cheers
08-05-2016, 05:41 PM
I got a couple engines out, I'll get some pics and send them over when i sort a pic of the metal intake pipe as well.
08-05-2016, 05:58 PM
Sound Cheers bud, just want to know where to clock the gt20 to, hot and cold side
09-05-2016, 10:47 AM
The hdi one will fit but it's not long enough for a gt20. On mine I got a local place to join two together which did the job.. Obviously you'd be better getting a new one made up
09-05-2016, 12:09 PM
Why would it not be long enough of its sitting slightly lower due to the adapter plate and I've clocked the chra?
09-05-2016, 12:32 PM
Where the hotside and chra sit further towards the offside there's just not enough length on the stock feed pipe. It's annoyingly close iirc but it just wouldn't fit.
09-05-2016, 01:13 PM
Bugger, Cheers
10-05-2016, 06:42 PM
I ended up buying a spare turbo off ebay...
Now I think from using the 307 hdi mani the turbo lines up perfectly regarding the oil feed etc which is good news, I'm very confident that I can use the the oil feed and return off the gt15. Just trying to get around the waste gate issue, I was hoping the gt15 one would got but it looks like it won't as the bolt spacings are different between the two
