Threads: 11
Car Model/Spec: 205 Dturbo (hopefully!)
Engine is going immediately to rev limiter when started.. its a dw8 with turbo intake and exhaust manifolds with a bosch pump. Before the swap i heard it running so im sure it was working but it stayed a long time in storage.. could it be a stuck governor or something 4lse? Any ideas? Thanks!
Threads: 110
20
How far in is the max fuel screw? I can't imagine that would cause it to redline but certainly hold the revs up a bit higher is wound in a lot.
Threads: 87
48
Could be running away, turbo feeding engine with oil
Threads: 41
Car Model/Spec: Dtractor
Sounds like the govnor weights were sticking.
