Gone slightly overboard and now the 6 is high boost
01-04-2016, 06:01 PM
can't beat a high boost 6! . . . . . .good lad . .
01-04-2016, 06:07 PM
you sexy mutha. high boost FTW
Thanks for the good times guys n gals. I might be back. Who knows. (01-04-2016, 05:46 PM)Xsikid Wrote: Hi all thought I would finally get a project thread up an running now I have the 6 back and work has calmed down a bit!!! Bought the car in December and was thinking just a rebuild and low boost but went to see Rich walker to pick up some bits and he had a high boost motor complete on the stand looking very lovely so I wanted one!!! As he got busy with all that I started to strip my xsi of crystals,exhaust, cyclones and numerous other bits to complete the standard look I wanted. Went a bit crazy with it all but now have a cracking looking 6 that goes sooooooo fast :-). Will be doing suspension next but unsure of which way to go with it. New T1r x4 with new genuine discs all round with ds2500 pads in- fab stopping power!! All looks very standard with very dull paint "sleeper" look. Will get pictures on asap cheers (01-04-2016, 06:01 PM)Mattcheese31 Wrote: can't beat a high boost 6! . . . . . .good lad . . (01-04-2016, 05:46 PM)Xsikid Wrote: Hi all thought I would finally get a project thread up an running now I have the 6 back and work has calmed down a bit!!! Bought the car in December and was thinking just a rebuild and low boost but went to see Rich walker to pick up some bits and he had a high boost motor complete on the stand looking very lovely so I wanted one!!! As he got busy with all that I started to strip my xsi of crystals,exhaust, cyclones and numerous other bits to complete the standard look I wanted. Went a bit crazy with it all but now have a cracking looking 6 that goes sooooooo fast :-). Will be doing suspension next but unsure of which way to go with it. New T1r x4 with new genuine discs all round with ds2500 pads in- fab stopping power!! All looks very standard with very dull paint "sleeper" look. Will get pictures on asap cheers (01-04-2016, 06:01 PM)Mattcheese31 Wrote: can't beat a high boost 6! . . . . . .good lad . . Your so right there bud it completely blows me away how quick it is!! Built by the main man Rich Walker so it's all good ?? (01-04-2016, 06:07 PM)bashbarnard Wrote: you sexy mutha. high boost FTW It's the only way to go soooooo glad I did ??
01-04-2016, 07:40 PM
builds 400 bhp engine, uses cheap rods and budget tyres :/
01-04-2016, 08:05 PM
I've looked at the graphs between LB and HB and where the power is delivered etc. I'm just not convinced the out lay is worth it.
I may be talking crap but I think a 2.2 engine would be better and try to develop more torque and usable power. Get some more photos up!
02-04-2016, 06:12 AM
(01-04-2016, 07:40 PM)welshpug Wrote: builds 400 bhp engine, uses cheap rods and budget tyres :/ To be fair the T1r are very good on the road but when she is a little more track ready I will get some decent tyres on. After all 70 is as fast as your allowed, right? As for rods I'm not sure if they are cheap but I trust Rich Walker so I have no problem with what's he has built- it's a completely brutal motor just needs a diff an suspension now to finish .:-)
Block bored out , honed and decked
As above Last one of the block all painted Few other bits that we painted Few more And more Nearly ready to start the build Head is back from machine shop Head is back from machine shop All painted ready to go Next step slot them home Spray bars in Crank at the ready Finally getting it together Bit more done All looks very shiney Bottom end is finished waaaaaahey Bottom end is finished waaaaaahey I have to admit even thou I love cars I didn't play a single part in building the engine. I do do some spannering but on the cleaner bits!! Even the pictures were taken by Rich W
03-04-2016, 03:26 PM
Do love a good clean engine
Shame they never stay that way lol
03-04-2016, 03:32 PM
Looks awsome more pictures of the rest of the build needed
Nice and shiney p
Taking shape Standard cams All done Loving it not long now Billet wheel is on can't believe how much lighter it is Inlet manifold is a work of art Can't believe the welds on this Old engine gone, air gone gone too ready for the new lump to go in Big hole And there she is Snug fit Used the magnex off the xsi with a few changes- welds were amazin Old to new Boost pipes all finished, helix paddle clutch with Valeo pressure plate Bit anal about the exhaust being in the middle so with some fettling it's perfect apart from being sooooooo loud Decat on and this was removed to take any restrictor out from exhaust The morrettes have gone replaced by the crystals
Graphite grey clones on with new t1rs put new fogs on also. Got some blanks also if I change my mind on them
(03-04-2016, 03:32 PM)7057sam Wrote: Looks awsome more pictures of the rest of the build needed Putting more on now it's a slow process Looks far better It's come a long way since December when the plan was freshen the engine up with new bearings,seals,gaskets etc then go low boost! Very happy on how it is for now. Undecided about suspension either coilovers or billstein b12 kit. Will do bushes, top mounts and drop links too (03-04-2016, 03:26 PM)Niall Wrote: Do love a good clean engine I'm hoping it will stay that way for quite a while as I only use it on weekends and in the dry (03-04-2016, 03:26 PM)Niall Wrote: Do love a good clean engine I'm hoping it will stay that way for quite a while as I only use it on weekends and in the dry
22-04-2016, 09:18 AM
(03-04-2016, 11:21 AM)Xsikid Wrote: Block bored out , honed and decked porn! Given the choice between Niall and the sheep. I would choose the sheep!
/Toseland
Small updates on the 6- was out for a hoon 2 weekends ago when the heater matrix decided it wanted to let go!! Luckily quite close to home so made it back ok. Turned out the plastic pipes that go into the matrix had split :-(. Anyways I went to Peugeot to get new matrix which they can get but no longer do the pipes that fit into it. So I ordered a second hand one from the bay and also a spoox bypass hose. For now I will do without a heater an matrix so I have removed it all. Can't believe how much it weighs!! Spent today taking out the Clifford alarm while the dash was out and got it all back together. While I was in Peugeot I ordered top mounts suspension arms with new bushes, track rod ends, drop links an ball joints, also have billstein b12 kit here so maybe next weekend I will pull the front off . Hopefully make a huge difference.
What a mess!! Got pressed plates on now too will get some pictures up when I get some more time
23-04-2016, 08:15 PM
What paint is used on the head and covers??
I used vht silver on my xud one...and it rubbs off
23-04-2016, 08:43 PM
Thanks given by: tigerstyle
Ok cool
![]() Fyi: love it Wishes for more power...
23-04-2016, 09:07 PM
23-04-2016, 09:11 PM
Oh shweet! Got some towels to put round it for all the dribble?
23-04-2016, 09:21 PM
23-04-2016, 09:36 PM
so was the block sandblasted? and what have you painted it with? it looks fantastic!
24-04-2016, 06:14 AM
Nice and shiney, everything looks right. Only concerns are the con rods and those God awful tyres.
Please trust what we are saying and get some decent rubber, I had a set around 7-8 years ago and they were dog shit.
24-04-2016, 07:12 AM
Yeah...I duno much(read anything) about high boost 6 setups...
But have heard people using the BE hdi box with more success than the gti6 box. Plus they are cheap right? And as for rods...again no experience...but anyone has these chinese rods go bang? T1rs on the other hand...ahhh dood, I missed that! Get some ad08r on them quick! You can get a whole set fot not much more than £225 iirc Wishes for more power...
24-04-2016, 07:25 AM
You're best off with a diesel box to make use of the power, you'll strip 3rd gear on a 6 box in a matter of weeks.
205 na derv box if you can find one, the uprated diff will fit in (23-04-2016, 09:36 PM)Eeyore Wrote: so was the block sandblasted? and what have you painted it with? it looks fantastic! Yes mate sand blasted and Simonize engine enamel (24-04-2016, 06:14 AM)Paul_13 Wrote: Nice and shiney, everything looks right. Only concerns are the con rods and those God awful tyres.Not sure on the con rods as they were reccomend by Rich Walker when he built the engine so I went with what he advised really. I'm gonna keep the t1r for the road as they don't get a hammering anyway but I will either get the yokos or triple 8s for the track.
11-05-2016, 09:46 PM
Good looking project mate, very nice looking engine. Look forward to having a peep at fcs.
keep up the good work. tyre wise I have federal rsrs and cant fault them. t1rs sadly are a pile of pooh, even on the road. cheers
12-05-2016, 08:15 AM
(11-05-2016, 09:46 PM)impotentials Wrote: Good looking project mate, very nice looking engine. Look forward to having a peep at fcs. Cheers mate it's been a bit of hard work on my side and rather a large wad of cash but it's nearly done. Just gotta finish swapping out the front end sat an Sunday then all that's left is diff and rear beam. Will be getting road legal track tyres when it's ready for track time thou
12-05-2016, 08:29 AM
Absolutely love that!
![]() Don't listen to the nay sayers, i highly doubt you'll have any issues with the rods! Yeah theres alot better tyres out there than T1r's but it entirely depends on your driving style! I used to swear by them & goodyear eagle F1's ![]() Looks a top quality build and im looking forward to seeing the finished article @ FCS! putting yourself down for front row?
12-05-2016, 09:43 AM
(12-05-2016, 08:29 AM)Matt-Rallye Wrote: Absolutely love that! Thanks bud . Everyone has a opinion and I respect that. Being a carpenter I've just used what was offered to me. It's the engine builders experience Iv paid for so will see what happens!! Puts a HOOOOFE smile on my chops when I'm driving it coz it looks like a bag of nails. A proper sleeper is what I wanted an that's what I have. Lots of rich kids round my way that get shown a clean pair of heels most times or they don't get far enough in front to make them smile. Ha ha I don't mind the toyo tyres I don't go mad on the roads but will be on track in the next couple months I hope will see proper rubber on then. See you at FCS . |
![[Image: 17b33c2a-8471-4313-992e-0a4b324cf926_zps2e63812a.jpg]](http://i143.photobucket.com/albums/r143/matt-taylor/17b33c2a-8471-4313-992e-0a4b324cf926_zps2e63812a.jpg)
