Threads: 136
11
They're not a straight fit! Had to bend a lot of metal out the way probably took half hour
Got them 2nd hand but lynx engineering (rich w) sells the kit.
I've just replaced the rear beam mounts to solid items as well
Threads: 91
2
Car Model/Spec: BMW 330Ci/VW Up/205GTi/205Mi16
Given 5 thank(s) in 5 post(s)
Watching with interest regarding the turbo change. Been thinking about it myself, maybe once the 205 is sorted....
Don't suppose there is any news on the GTi6 bars and XUDT crank?
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 136
11
Gti6 bars are out
I need to pop to Ryan's to get the engine crane so I'll grab the crank while I'm there
Threads: 18
10
Car Model/Spec: 3 x 205 GTi & 306 HDi
(07-02-2016, 08:22 PM)Alan_M Wrote: Watching with interest regarding the turbo change. Been thinking about it myself, maybe once the 205 is sorted....
Good to see that you're planning your retirement projects already...
Threads: 91
2
(07-02-2016, 08:56 PM)Paul_13 Wrote: Gti6 bars are out
Very much appreciated Paul!
(08-02-2016, 08:47 AM)powerandtorque Wrote: (07-02-2016, 08:22 PM)Alan_M Wrote: Watching with interest regarding the turbo change. Been thinking about it myself, maybe once the 205 is sorted....
Very funny beatnik......the idea is there, that's the first step!
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 18
10
(09-02-2016, 12:00 PM)Alan_M Wrote: Very funny beatnik......the idea is there, that's the first step!
Too many ideas and not enough implementation of said ideas!
Threads: 136
11
Desperate to get working on this turbo!
going to chat with Ryan later see if he can make me a plate
Threads: 136
11
Got the plate off Rryan Cheers for that bud. Should be nice and easy to make this up after looking at it
Threads: 136
11
I've got everything apart from the air intake sorted which is worrying me http://306oc.co.uk/forum/showthread.php?...20&page=10 same prob as Dr jekyll etc.
Other option is like what is shown on there and bring it up between the cambelt and bulkhead but I ideally want to retain the standard air box...
I'm going to do a bit of research and see what the 307 air intake is like for the rfh4
If not modify the 406 one I've got.
Do people just link the pipes on the egr warmer/cooler directly behind the rocker cover? I'll be doubt away with the whole egr system
Threads: 136
11
Threads: 136
11
Another option shamelessly stolen from uberderv
Threads: 117
119
That's a beautiful bit of pipe and a brilliant idea.
Threads: 136
11
If you've removed all the egr stuff, you should be able to move the air intake out slightly more to miss the egr port on the 307 hdi mani. Looks like there's enough space
Threads: 49
2
Car Model/Spec: 306 HDI Estate + 205 HDI
What about cutting the egr port off and welding it for more space?
Threads: 136
11
Was thinking of doing that to be honest, not too confident welding cast if I'm honest
Threads: 49
2
Or using oval pipe for the upper section which goes into a 180 degree silicone reducer. Can't help on the welding other than you'd have to use a pack of dissimilar metal rods and try and preheat/controlled cool down. Seen it done before with good results.
Threads: 136
11
Started work on the manifold
Pikey!
Got one of the manifold studs out, one snapped and I gave up as I lost daylight
Threads: 91
2
(21-02-2016, 07:54 PM)Paul_13 Wrote: Started work on the manifold
![[Image: 20160221_164913_zpslvp1bcvy.jpg]](http://i1224.photobucket.com/albums/ee365/paul13205/20160221_164913_zpslvp1bcvy.jpg)
Is that a bag rust by your foot?
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 91
83
It's a Ford isn't it?
Threads: 18
10
25-02-2016, 04:40 PM
(This post was last modified: 25-02-2016, 04:41 PM by powerandtorque.)
(25-02-2016, 04:14 PM)Ruan Wrote: It's a Ford isn't it?
eBay advert Wrote:"Requires light restoration, easy project"
Threads: 136
11
 my previous cars all rolled into one
Threads: 18
10
I'm not sure your cars generally last long enough to get to the point of rusting...
Threads: 136
11
Oi....
I've owned your old car for nearly 3 years I think now.
My silver gti was the longest standing that was 6/7 years I think
Scary thing is, I've owned a 205 for over 10 years now. Got my first one at 16 and I'm 27, had a brief break in between
Threads: 136
11
Just seeing what angle I need to clock the turbo, nice and easy to clock these!
I'm guessing on a hdi its a banjo bolt on the oil feed? I'm going to whip the union connector out of the gt20, hopefully from what bash said it should fit. I'm planning on putting the oil feed at the same angle as the hdi turbo so I can literally just put the hdi oil feed on. Same with the oil return if the flanges are the same
Precision engineering
Threads: 136
11
Out with the old in with the new ones
£150 from Peter lloyd racing
Threads: 91
2
What spec Bilstein?
2001 BMW 330Ci
2012 VW High Up
1988 205 GTi 1.6
1990 205 Mi16
Threads: 136
11
Threads: 67
5
Car Model/Spec: 306 Sedan - Ph1 Dturbo
Given 6 thank(s) in 6 post(s)
You wally! If you asked if send you a card template for the adapter! Mine matches up beautifully!
![[Image: bba77d271c8ce9dc0bbb8c4bc914c773.jpg]](http://uploads.tapatalk-cdn.com/20160301/bba77d271c8ce9dc0bbb8c4bc914c773.jpg)
As for intke thats best ive got atm. Seen the other you posted from ubederv, looks epic but found a few clearance issues with the brake servo when looking closer. Will tell you next week how i get on as its d-day for the turbo fitting
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
Threads: 136
11
Mines a different bolt pattern to yours unfortunately
Yeah if you could, I'll buy your other 306 hdi air intake pipe you if you get out of in one piece
Threads: 136
11
New plate is here
I'll get round to doing it tonight if I get time
