Threads: 80
Car Model/Spec: hdi estate bus cherry red hdi
Well I been meaning to start a project of some sort for a while now just haven't had the time as I'm always fixing the daily driver
I am thinking of building up a 2.0 hdi as I have one in a doner I'm going to take out
I am unsure on what car I want to stick the engien in was thinking 106 maybe never heard on anyone putting a hdi in to a 106 before
This project will be slow going to start with so bare with me the
Quick pic of the doner
Threads: 80
Threads: 42
28
There's a good reason you dont find them in 106's!
they don't bloody fit nicely! The engibe bay was designed for a bolt upright exhaust on the front tu engine, not a 30° lean back xu/xud/dw with exhaust on the back.
205 405 309 would be a better recipient.
Threads: 80
That why u wanted to have a go a putting one in as it would be a challenge you no of anyone that done it before ?
Threads: 143
10
Car Model/Spec: Ph3 XUD
Seen an XUD in a 106, was here/.net years ago. 106 NAD has a rear exhaust too.
Threads: 80
I seen a few xud but never a hdi motor in a 106. Don't think I will be able to get the blower down the back anyway so Im going to have to be box mounted
Threads: 448
51
Will be a bloody tight squeeze, think a hdi 205 would be better
Threads: 371
29
Car Model/Spec: ford fiesta
I'm with everyone else 205 base same mounts etc. You can fit them in 106 as I seen xuds in them. But to name a few issues, driveshafts need making, gear linkages need making, chassis needs "notching" to fit gearbox in, engine sits at wrong angle, engine slightly too tall so needs dropping lower than normal. These are just the ones off the top of my head. A 205 is bolt in. Wire up, away you go. Far easier and cooler and safer imo.
104 convertible be my choice
Don't be boring and follow the crowd
Threads: 42
28
Definitely wont go in a 104, engine bay is too narrow and not tall enough, my brother had a 1.1 ZL.
Threads: 80
Hmm only problem with the 205 you can't pick up a cheap one
Threads: 266
18
Car Model/Spec: 205 DTurbo
(18-02-2016, 08:38 AM)daniel909 Wrote: Hmm only problem with the 205 you can't pick up a cheap one
I got a 3 door, white, 1.9 DT, running, needs MOT but done 500 miles since last MOT. £300.
Bosch as well.
Threads: 80
Don't have 300 hundred pound spare ATM as I got to pay for a holiday at the end if the week also my rent coming out but if u still have in next month I might have it off you
Threads: 42
28
you're in Cornwall, that's where half the cheap 205's are! scrap is on its arse so you should be able to find an mot fail for a few hundred at most.
if you havent a few hundred quid for a decent donor car, then you can forget making it fit in a bloomin 106.
Threads: 19
This is Cornwall, baler cord is plentiful.
Crack on Rhys, anything that didn't have a HDi in from the factory I'll be interested
Drash on lad.
Ignore mcwelshboring
81
evertyone has identified the issues.
diggerz on .net did it ages ago. Project thread below.
http://www.theywhoshallnotbenamed/forum/...on-Project
Threads: 80
18-02-2016, 10:50 PM
(This post was last modified: 18-02-2016, 11:45 PM by daniel909.)
Eeyore thank you for the link but Im wanting to stick a dw10 in not a xud
Threads: 213
Car Model/Spec: HDI
Even a lightly tuned HDI would be sweet in a 106/205, would love to see one in a 309 or 405 though!
Threads: 371
29
(18-02-2016, 10:50 PM)daniel909 Wrote: Eeyore thank you for the link but Im wanting to stick a dw10 in not a xud
Same basic engine block size shape gearbox mounts etc so you will run into those exact issues.
Threads: 80
19-02-2016, 01:18 PM
(This post was last modified: 19-02-2016, 01:21 PM by daniel909.)
anyway had a few hours spare last night so started to strip down the doner an pull the engine out.
got a bit pissy when i took the front wheels off to find out the nuts had been welded on the drive shafts
Ah well, you'll need to sleeve/weld them anyway!
Threads: 80
just why would u weld the nut on anyway
Threads: 465
114
Car Model/Spec: Vauxhall
(19-02-2016, 02:21 PM)daniel909 Wrote: just why would u weld the nut on anyway
because two new drive shafts would double the value of the car
Threads: 80
19-02-2016, 03:01 PM
(This post was last modified: 19-02-2016, 03:02 PM by daniel909.)
i got bits and bobs turning up now gaskets, belts, few other bits and bobs and a turbo which i got at a pretty good price
just checking i have brought the right belt 6PK1175 for ac removal ? anyone no off the top of there head
Threads: 127
33
Car Model/Spec: ZX Volcane TD
will be a tight squeeze, but an interesting project for sure
makes me laugh the lengths people go to bodge things back together. maybe not so much when it happens to me
Threads: 80
(19-02-2016, 03:12 PM)zx_volcane Wrote: will be a tight squeeze, but an interesting project for sure
i cant really talk some of the bodges i done in the past
Threads: 61
11
Sounds interesting,can't wait for it to be squeezed in
Threads: 213
Car Model/Spec: HDI
Yeah that belt length is spot on if your not running AC, got 1185 on mine with no issues (because it was £2.50 posted!)
Threads: 80
20-02-2016, 05:56 PM
(This post was last modified: 20-02-2016, 05:58 PM by daniel909.)
(19-02-2016, 04:16 PM)MY95 Wrote: Yeah that belt length is spot on if your not running AC, got 1185 on mine with no issues (because it was £2.50 post [quote pid='577289' dateline='1455898576']
Ideal thanks mate
[/quote]
Well finished ragging the engine
out today thanks Darren for the lone of your crane
[/quote]
