10-02-2016, 06:05 PM
Will a bosch fuel pump from a 2.1 with lines and injectors fit a 1
9 td?
9 td?
2.1 pump in 1.9
9 td?
10-02-2016, 07:59 PM
Yes.
But it will be like swapping a 50pence piece for another 50pence piece. Same pump/injectors! Wishes for more power...
Thanks given by: danblp
its just i have a lucas and wanted a bosch
is it a streight swap?
10-02-2016, 08:15 PM
Yes apart from injector lines wont fit and you'll need to move studs on Lucas pump bracket
10-02-2016, 08:21 PM
the lines with the 2.1 bosch wont fit? getting bosch pump lines and injectors cheap
10-02-2016, 08:32 PM
Nope they wont. Will need bending.
Thanks for the good times guys n gals. I might be back. Who knows. Thanks given by: danblp
10-02-2016, 08:45 PM
so move it to the other holes which lucas isnt on bend the pipes will injectors fit or just use lucas ones?
11-02-2016, 07:30 AM
Move studs, note firing order of Bosch before removal, different to Lucas, fit to 1.9 with Bosch injectors. Bend a combo of Lucas and Bosch lines to fit as none will be correct. They have different lengths as they're off a 2.1
11-02-2016, 07:32 AM
Does it need bosch injectors or can I use lucas as guys got one injector stuck in?
11-02-2016, 08:36 AM
If you want the bed out the pump use Bosch, however it will run in Lucas just not as effectively
11-02-2016, 08:57 AM
ok cheers one injectors stuck in haha
11-02-2016, 09:47 PM
will injectors from a 1.9 bosch work with the 2.1?
11-02-2016, 09:51 PM
Yeah they're the same.
11-02-2016, 10:07 PM
hopefully have a bosch pump tho been after one for afew days haha hard to get
