	Threads: 214
Car Model/Spec: 306 hdi meridian
		13-12-2015, 11:45 AM
(This post was last modified: 13-12-2015, 11:46 AM by Welshy_Pete.)
		The FMIC is that only worth fitting if you have a stage 2 remap or will it make any difference on a stage 1 remap?
What difference will you see on a standard ecu and stage 1 ecu with FMIC.
306 hdi
Thanks
	Threads: 4
6
	Given 7 thank(s) in 7 post(s)
		It's only worth doing if you actually get a stage 2 map, otherwise you will just have the stage 1 power, maybe 1 to 2 bhp more thanks to the cooler charge.
	Threads: 136
11
		I found having the FMIC on stage 1 freed up the engine a fair bit
	Threads: 186
38
Car Model/Spec: MG ZR VVC
		My stage 1 with cooler seemingly stopped smoking under heavy load. MPG picked up a abit as well from what i recall but this was many moons ago
		Mine picked up a bit of mpg and power, but then it was a heavy stage 1 to begin with.
