01-12-2015, 04:45 PM
[attachment=26001][attachment=25837][attachment=26001][attachment=25837][attachment=26001][attachment=25837]Hi, I'm hoping that you guys and gals can help
I have a ph2 D Turbo, and having an issue with the longer driveshaft mount that also runs the speedo.
I have been trying to get another 1 on and so far broken 2!
The driveshaft itself is off and out of the way, but when bolting the new unit on it only went in so far then the lower of the 3 bolts snapped the casing, got a replacement unit, went a lot more gentle and even done each bolt a turn or so at a time, again before the unit even touched the rear of the gearbox, again the lower bolt snapped the casing!
I'm confused at where I am going wrong, and need to find an answer before I break another, ive tried google search and other things but not found much info other than how to remove it, well its removed, but no idea on how to bolt it back on without breaking it
thanks in advance
thanks in advance
