gearbox changing
gearbox changing
Hello just recently bought a 306 gti6 would like to change gearbox from a 6 speed to a 5 speed, can I use the be3 gearbox from a zsara gti
Yes you can.
Tinkerer of 306gti6 trackday racer, less stuff, more hard, more umpf, more stop.
Thanks given by: Steve 306 gti6
(09-11-2015, 02:47 PM)Janne L Wrote: Yes you can
Thank you
Would I be able to use the gti6 clutch or clutch from the zsara
Is it a xsara vts? AFAIK there is no xsara gti, it's called vts.
If the answer to my question is yes, then the clutch will be identical.
(09-11-2015, 06:58 PM)Janne L Wrote: Is it a xsara vts? AFAIK there is no xsara gti, it's called vts.
What would he gain in changing the gearbox?? (6 speed vs 5 speed)
(Newb)
I've been told that the gearing would be better for sport as a six speed box is not the best .
I use the 5 speed Xsara Be3 box on my Rallye, i prefer the ratios.
Standard GTi6 clutch.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
nothing wrong with the 6 speed unit other than not being quite as strong.
xsara vts uses the same clutch,. its a direct bolt on, just don't use the reverse strop cable.
