12-10-2015, 12:54 AM
		A friend has a 306 D-Turbo (DW10) it is not starting. It turns over but does not fire, sometimes it will start with enough cranking but then it can randomly cut out up the road and refuse to start up again.
The in tank pump is working ok and sending fuel to the filter housing.
I have read the fault codes and found this:
The first two are normally standard faults for DW10's, the fuel high pressure monitoring what is this most likely going to be:
![[Image: 12166490_10208020260970051_1839650510_n_zpsuye3q9tt.jpg]](http://i908.photobucket.com/albums/ac289/406executiveHDI/3gs/12166490_10208020260970051_1839650510_n_zpsuye3q9tt.jpg)
I also read the other fault codes stored in the car, the airbag one is not relevant but would the key sync issue affect the immobiliser:
![[Image: 12166436_10208020261370061_602597904_n_zps536rpnqo.jpg]](http://i908.photobucket.com/albums/ac289/406executiveHDI/3gs/12166436_10208020261370061_602597904_n_zps536rpnqo.jpg)
Some other readings, not sure if they help:
![[Image: 12167051_10208020261490064_1603170617_n_zpsw0ierptu.jpg]](http://i908.photobucket.com/albums/ac289/406executiveHDI/3gs/12167051_10208020261490064_1603170617_n_zpsw0ierptu.jpg)
This is a video of the car trying to start:<br />[/img]
