03-10-2015, 08:07 AM
Me too, keep up the good work and let us all know how you are progressing
![[Image: 9fa12c59-0c3d-4413-968d-6a7840ff068f.jpg]](http://i693.photobucket.com/albums/vv295/highwayman306/9fa12c59-0c3d-4413-968d-6a7840ff068f.jpg)
XU10J4R(S) Project !
![]() Stage 1 HDi DTurbo Diablo 5dr, "Dee-Dee"
03-10-2015, 10:04 AM
That is a very fresh engine! I'm jealous! Mine looks like shit haha
05-10-2015, 07:35 AM
Nice looking engine, always nice to see another painted lump :-)
Here's mine:
Tinkerer of 306gti6 trackday racer, less stuff, more hard, more umpf, more stop.
05-10-2015, 08:08 PM
It looks nice and clean, looks beautiful
06-10-2015, 12:50 PM
Thank you very mutch
08-10-2015, 12:58 PM
what engine loom will you be using?
i assume your using a GTI6 engine loom just be warned the PH2 loom is different to the PH3 loom they are interchangable but you have to swap some sensors over as the plugs are different PAS sensor MAP sensor Oil pressure sensor gearbox reverse switch also you are using the early ph2 cam pulleys that are prone to crack it may be wise to upgrade to the later PH3 pulleys
https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
08-10-2015, 01:36 PM
I use the XU10j4R engine bloom, i tested the connections and it looks good at plugs.
Thank for the information about cam pulleys, i did not know You have a photo of the phase 3 pulleys ?
08-10-2015, 04:25 PM
later PH3 pulleys
![]() cracked ph2 pulley ![]()
08-10-2015, 04:38 PM
Woa... Ph2 pulleys are really shit !
09-10-2015, 04:01 PM
(This post was last modified: 09-10-2015, 04:05 PM by insomaniac45.)
wow, your lucky you spotted that, hate to think of the damage it could have caused..
![]() looking back through the pics, it looks like you have ph2 pulleys notice the bend in the spokes, PH3 do not have that bend swap them out just to be safe is my advice. Beautiful engine beautiful build, be a shame to risk any damage from a cracked cam pulley.
Not always Grumpy!!
306 Cabby SE, 2.0l 16v
10-10-2015, 03:08 PM
(This post was last modified: 10-10-2015, 03:15 PM by maxzy.
Edit Reason: Detail missing
(08-10-2015, 04:25 PM)cully Wrote: later PH3 pulleys My 406 SRI with XU10J4R had the same problem but so lucky there was no abnormalities ! but after that around 1 year, the 3 locking bolt of Intake side was loose that made the valve bent and piston scratch ! Also, The RFV upgrade with RFS part that I have done with my 406, I got extra 15 WHP and 18.6 lb-ft at the same Dynamometer that you can feel the difference. Remark : I put only Intake manifold, Cams, Custom Intake and Exhaust system with RFV loom. Some of my friend that also have the exhaust manifold and remapped ECU MP5.2 got extra 30 WHP !
1999 306 GTI-6 PT81 & Remapping
2000 406 SRI 2.0 Turbo 6M/T @ 1 Bar Boosted ![]()
14-10-2015, 08:10 AM
Yes I have to find the phase 3 pulleys .
I do not want to break everything because of pulleys. That would be stupid . By cons to find it will not be easy ... Maxzy: 30 hp without the pistons of the RS ? It's a good job of keeping the ecu XU10J4R ! You have a topic with your work?
02-11-2015, 09:14 AM
good work
There are a pictures, that i had not seen my friend Next time for your Ecu/remapping, take a Megasquirt??. what did you think?
14-01-2016, 09:43 AM
Hi all !
I could move my car frame ! Rear end, it is ready to ask ! ![]() ![]() I asked the front brake 307 Hdi in 283x26
Now pictures of major project !!
Installation of the rear axle !
It was to low for my taste
For the front train !
I don't have a picture :
![]() I ask triangles, Kayaba ultra sr shock absorber, new pivot and bearings
I put together the back
Installation of new wheels and rods !
[url=http://www.hostingpics.net/viewer.php?id=328525IMG1478.jpg]
26-09-2016, 09:39 PM
helo
I love this projects. I am also working on something similar. I have original XSI 2.0 16v but I want to keep the original pistons. exhaust manifold is already fitted (works perfect) now i woking on the inlet manifold (but i think you use original RFV injector is better or must find something with similar parameters, only more cc/min like 0280156038) and RFS cams are ordered. i have same problem with a max lift of the valve springs should be 9.65mm and RFS cams have valve lift 10mm. how to solve? and you should buy this part http://www.ebay.co.uk/itm/Genuine-Peugeo...1983246312 it is water pipe on the back of engine if you mounting -RFS exhaust manifold u need it. Srry for my english
