	Threads: 448
51
		The rallye has a slow start up issue, turn the key the engine will try to turn over and the engine will do what sounds like a turn every two seconds. Does this like 2/3 times and then will fire. Also when cranking.
Sometimes almost seems like a dead battery.
Just the first of many problems to sort haha
	Threads: 11
Car Model/Spec: 306 GTI-6 trackday toy
		1. Check battery voltage at rest and while cranking.
2. Check to make sure battery cable that connects to starter is in good order and correctly fastened.
3. Check voltage drop between battery negative and engine block while cranking.
4. Check voltage drop between battery positive and starter (or alternator) positive terminal.
5. Report results back here for analysis and further crunching of available data.
Tinkerer of 306gti6 trackday racer, less stuff, more hard, more umpf, more stop.
	Threads: 448
51
		Man looks like I need a tester then! Will have to order one tonight
	Threads: 448
51
		Well I'm free today. Till 5
I'm off all day Wednesday?
	Threads: 136
11
		Give the starter a good whack with a hammer and report back
	Threads: 448
51
		I swear I messaged you! Oops haha
I'm gunna take a look at the starter tomorrow. Engine didn't run for 3 years so could be a starter issue
	Threads: 448
51
		Ahh yeah, remember seeing your status come to think about it haha
	Threads: 23
Car Model/Spec: 306hdi
		 (20-08-2015, 02:58 PM)Matt Wrote:  The rallye has a slow start up issue, turn the key the engine will try to turn over and the engine will do what sounds like a turn every two seconds. Does this like 2/3 times and then will fire. Also when cranking.
sounds like a flat battery?
306 HDI
stage 1+ remap
piper cross air filter
hoffmann race centre pipe
hoffmann de-cat pipe
sportex rear tailbox 3"
	Threads: 136
11
		Or sticky starter /solenoid
	Threads: 23
		any news on this?
306 HDI
stage 1+ remap
