Fan relay specs on a hdi
Does anyone know what the specs are of the fan relays on the hdi i think their 12v 5 pin 35v. Does it have to be 35v as I have got 30v and 40v relays thinking of using the 40v relays but not sure of the electrical draw on them. Anyone have a idea.
Sorry ment amps not volts auto correct on new phone arrrh
the 30 35 40 is the current rating check again i think you will see it is a *A* not a *V*
if you replace a relay replace it with one the same colour you should be ok then Wink
GTI6 Info
Cheers realise after i posted it that my phone had done a auto correct on the post. Thanks will look for some
