02-08-2015, 08:33 AM
Hi Guys,
I have decided my next project will be to replace the 3 large capacitors that are in the ECU that control the pulsing of the injectors. Being from an electrical based job I know that with age capacitors wear and can really loose huge amounts of both capacitance and also the ability to handle the correct voltage, let alone keep it stable. Some even pop open and completely break apart.
I know the ones in my ECU probably aren't at that stage but just for a challenge and to see what it may do I want to take the ECU apart and replace the capacitors with new ones from a good company such as Panasonic, Nichicon, Rubycon etc.
My plan is basically to buy another ECU like mine. I believe that there are two types? One with a single plug on it and one with 3?
Once I have the new ECU what I want to do is take the map from mine, flash it onto the new one so I have two identical ECU's (In case I screw mine up) and then replace the caps in my one and put it back into the car.
What sort of software and connections will I need to be able to load and unload the maps to and from the ECU's?
Thanks for any help
Jack
Thanks for any help
Jack
haha
