Swap 1.8d to 1.9 td
Hey Hey
My 1.8 diesel engine is becoming boring to me with only 60hp.
I was thinking to swap to 1.9 td 92hp.
Can you guys tell me if it is plug and play ?
A friend of mine said it is but i wanna know from other people Big Grin
Greetings from Portugal
Pretty much plug and play. Use as much of the 1.9 as possible. Best get a donor car
(20-05-2015, 05:49 PM)bashbarnard Wrote: Pretty much plug and play. Use as much of the 1.9 as possible. Best get a donor car
ty for the quick response man Smile
i will buy the engine on the waste (crashed cars)
Best thing. Everything is pretty much plug and play. Just use the wiring harness off the 205. If you have pas you are best to ditch it off as it runs on the back on the 205 from memory and front on 306. 205 drive shafts will fit. You can use the 205 box if you want. If you use a 1.9 box though it has longer ratios. I think that's all I know.
(20-05-2015, 06:12 PM)bashbarnard Wrote: Best thing. Everything is pretty much plug and play. Just use the wiring harness off the 205. If you have pas you are best to ditch it off as it runs on the back on the 205 from memory and front on 306. 205 drive shafts will fit. You can use the 205 box if you want. If you use a 1.9 box though it has longer ratios. I think that's all I know.
Hummm, let's see if i get it  Blush
What i need:
- Wiring harness off the 205
- drive shafts from 205
- gearbox from 205
My friend told me too that 1.8 gearbox is the same as the 1.9 (piece of cr*p).
didnt understand that part,  Nospeak
Yes yes and no. You can use the 1.8 gearbox. But it will rev really high on cruising. The 306 box is better. If you really want to drop cruising revs a 306 hdi box will fit.
Iv got 2 gearboxes already converted if you need them, use the 1.8 water system and swap all the sensors for the 205 ones then the harness will be plug and play check my project thread for more info
Current cars
Subaru Impreza 2.0d - Daily
(20-05-2015, 07:24 PM)td_dan Wrote: Iv got 2 gearboxes already converted if you need them, use the 1.8 water system and swap all the sensors for the 205 ones then the harness will be plug and play check my project thread for more info
But i'm a student and i do not wanna spend to much money on 1 time.
I prefer to do the basics, then going to upgrade  Confused
As i said read my thread, but really just buy a smashed 306 with working engine and tiu will have everything needed
Current cars
