hdi engine
hdi engine
would anyone have a hdi engine removed that they could take a picture of the bolts on the inlet manifold and exhaust manifold? Rep will be given Smile
[Image: 13073041_458228241037318_1249062425_o_zpsoh6qf7gu.jpg]
What do you need to see?
[Image: IMG_0026JPG-1.jpg]
Exactly that ^^^^ Smile
Thanks Big Grin
Should also note theres no EGR on that pic...so yours will have more shite in the way... lol
(06-05-2015, 09:19 PM)Toms306 Wrote: Should also note theres no EGR on that pic...so yours will have more shite in the way... lol
forgot about that :O Smile all that crap will be coming off anyway Smile
EGR Gubbins will be similar to this
[Image: DSC01044.jpg]
Are the inlet manfold bolts torx's? Or allen bolts?
Allen heads on top, 13mm nuts on bottom
how many bolts are holding the turbo on? i have the 8 nuts and spacers off. one allen bolt near the sump. is there any more?
Aren't there 2 allen bolts on the support bracket? And 1 13mm nut/bolt on the other 'leg' of the bracket?
(07-05-2015, 04:51 PM)Toms306 Wrote: Aren't there 2 allen bolts on the support bracket?  And 1 13mm nut/bolt on the other 'leg' of the bracket?
i could only see 1 allen on the bottom and a bolt on the top of the bracket. the  Censored wont move :/
I'm sure you were told it was a pain in the ass. Tongue
It's been nearly a year since I rebuilt a HDi and I must admit I can't really remember now, sure there shouldn't be anything else holidng it on though. All the EGR shite is removed yeah?
(07-05-2015, 04:57 PM)Toms306 Wrote: I'm sure you were told it was a pain in the ass. Tongue
shhhh its really easy  Itwasntme
all egr is gone, just need to get the  Censored turbo moved so i can get 3 last bolts  Undecided
Hmm, don't know without seeing it. Is the bracket free or is that still solid? May have to loosen both of sides of it if you haven't already. Also are the oil pipes in the way at all? Both are flexible so shouldn't be that though.
You need to remove the big aluminium inlet pipe too, its bolted on the inlet side of the turbo, with the 8 nuts and studs out there is just the exhaust and the lower support bracket(2 allen key bolts and 1 bigger nut and bolt 16mm iirc) holding the turbo and manifold on
the stupid thing is out, there was 2 allen bolts  Itwasntme
it was definitely leaking as there's oil everywhere and you can see where the gasket failed. only took 6 hours to remove it  TMI
Yay I was right... lol
6 hours!! I can have a HDi engine out in 2... Tongue
Thanks given by: tysonbully2k12
(07-05-2015, 05:50 PM)Toms306 Wrote: Yay I was right... lol
6 hours is good time Wink  got half way through and said it would be easier to take engine out  Rofl
Have to put it all back together now  Doh All this effort for a 5euro gasket  Huh
Take the time to clean out the inlet manifold and thoroughly clean the mating faces on head and manifold or else you will be removing it all again Big Grin
(07-05-2015, 05:54 PM)tysonbully2k12 Wrote:  All this effort for a 5euro gasket  Huh
And that's why people don't bother fixing minor leaks on these... lol Good luck for the refit...see you in another 6 hours... Tongue
(07-05-2015, 05:58 PM)HDi--Power Wrote: Take the time to clean out the inlet manifold and thoroughly clean the mating faces on head and manifold or else you will be removing it all again Big Grin
ill be cleaning it but if it leaks i aint taking it off again. it can stay leaking Big Grin
i know for next time not too touch it Smile im hoping around 4 hours Big Grin should fly through it Smile
If you spent less time online you would be done by now Wink
(07-05-2015, 06:17 PM)HDi--Power Wrote: If you spent less time online you would be done by now Wink
LOL
 Copper grease everything upon reassembly...... Just for future developments.
i have the inlet back on Big Grin Big Grin
just to bolt exhaust mani up and put everything back together Smile  hopefully it fixes the problem Big Grin
Well done lol, you've clearly got more patience than myself!! lol
(08-05-2015, 02:38 PM)Toms306 Wrote: Well done lol, you've clearly got more patience than myself!! lol
wasnt too bad once i got to know where all the bolts where, the worst bit was the  Censored birds in the shed tweeting all the time. had to put the radio on full blast  Nospeak
Users browsing this thread: 25 Guest(s)
