Too much fuel?
Hi guys,
When I'm driving my 6 I can always smell petrol, like the cars not burning it off properly?
Can this happen? Or is it another issue?
All comments welcome as always! Smile
As in unburnt petrol smell or burnt? Could be exhaust blowing bit?
Not sure if it would apply to a petrol but on my hdi the constant fuel smell was diesel leaking around the injectors
If its blowing before the cat, it can smell quite rich. If not, i would say either your coolant temperature sensor or lambda sensor is goosed and more than likely lambda.
Injector seal, pipes to the fuel rail, decat, exhaust leak, pipe to charcoal canister not connected right
P1 XSi track car
2.4 LWB T4
Thanks for the replies guys, sorry I forgot to subscribe to the thread!
I've just had a brand new back box put on it, and the mid section has been removed and replaced with a 2.5" stainless steel pipe. The cats fine as my mechanic has checked it when he put my back box on.
It smells like there's unburned fuel when I'm going along at 30, smells like she's running really rich?
Also I stuck a tenner in her earlier and got about 40 miles out of her and I was taking it relatively easy! Would getting her plugged into a diagnostics machine find or remedy the issue? If there is one?
Best bet is putting on emissions tester at mot garage that way youll know if its rich
A diagnostic would help, especially if you can see live lambda readings. Or as Seb says, use an emissions test.
Could be a split fuel pipe in the engine bay, worth checking them as they do start to crack with age.
Thanks for the replies guys! Smile
I'll get her plugged in next week when I'm getting the driveshaft seal and gear box oil change done.
