Threads: 371
29
Car Model/Spec: ford fiesta
Im thinking about removing my pas on my motor. Almost every car I've had without pas feels better. Except when parking. Id just like to hear from people who had done it? How they had done it? (ram removal or new rack) Were they happy with the results?
Threads: 371
29
anyone? im being impatient for once.
Threads: 581
195
Jonny all the numbers would be the guy to talk to about this. Removing the pump, ram and pipework is simple but you will end up with play slightly in the steering due to a slight gap either side of the shuttle being taken up by the fluid pressure. I think he welded it up but I'm not sure what he welded lol
Threads: 371
29
Fair enough. ill have the engine out when i do this so i could weld it at that point if need be.
Threads: 117
119
Yours was pretty heavy going in slow corners, Jonny, did feel nice though. Aren't you planning on doing something with a 2.1, bash? That'll be hell to manoeveur under about 15mph with all that weight over the front.
Threads: 581
195
Could just fit EPAS? And then have it switch off above x mph? Still got your pansy park assist so best of both worlds?
Threads: 371
29
Yeah but its only a little extra weight. Lol. That's when I'm thinking of doing it while engines out for conversion. I did look into epas but I like the idea of no pas. So its a little harder to park, that's like 1% of total driving time in my view.
So remove ram and weld up play. Seems simple enough. My mot tester is fine cant see it being an issue.
Threads: 386
87
Parking maybe 1% of driving time but its probably like 50% of steering! I wouldn't go with no PAS but each to their own, 306 steering is heavy enough as it is lol.
Threads: 371
29
306 steering isn't heavy at all. Have you ever drove an old landy!
The question that I really want to ask is Jonny. Was it worth it?
Threads: 371
29
Each to their own I guess. I like the "feel" of non pas. Makes me feel like I'm driving the car
Threads: 371
29
Just to let people know. Lo e the pas delete. Its epic!!
Threads: 11
Car Model/Spec: 306 GTI-6 trackday toy
You ppl are giving me ideas!
No pas means no pas pump, together with no AC means only the alternator left, so no need for a belt tensioner, and no need for such a big/heavy alternator mount... Hmmmm I'm liking where this is going!
Threads: 371
29
That's what I've done. Stretch belt FTW
Threads: 67
5
Car Model/Spec: 306 Sedan - Ph1 Dturbo
![[Image: 5e078564ea54c9cb889a5ab0ab97df5d.jpg]](http://images.tapatalk-cdn.com/15/04/21/5e078564ea54c9cb889a5ab0ab97df5d.jpg)
Did my pas delete the other month, easy [FACE WITH STUCK-OUT TONGUE AND WINKING EYE]
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
