HELP
hi all i think i have messed my 306 up but i thort i ask to see if there anything i can do to save it my m8 sed to put red in my diesel tank so i did and the next time i went to start my car it started but went in to limp mode and now it wont come out i changed the fuel and rail sensure wat more can i do my car is a 306 d turbo hdi if u can help me out that be good thanks
Tried emptying the tank and putting legal white diesel in and flushing it through? Smile
Need to clear any codes and then take it for a spin so you can what comes back, and watch out for plod.
He says he changed the fuel... Though a bit of punctuation may have helped make it readable.
You need to change the filter as well....if it gets checked it'll obviously be red. You need to get a fault reader on there and see what codes it's bringing up.
Change the fuel, change the filter, check the pump, reset the ecu by removing the battery for 10 minutes.
