Couldn't think of anything good to put in here!
Hi folks, thought I'd say hello, I've just bought a heap of a 306 HDI estate to run around in so will inevitably need some advice when it breaks. Also drive a BMW 740i and have a Cavalier SRi lying in the garage waiting for better weather/me to do something.
Looks better than it is, covered 227000 miles so far! Currently it's owe me £250 including buying it and MOTing it.
[Image: Pug%20017_zpsfytzrctt.jpg]
Cheers,
Lugy
Why hello there. 250 is cheap. Give her a good service fix any niggles then chuck a stage 1 map on.
Welcome to the club, looks lowered, unless its loaded up to the balls Smile
Welcome Smile
welcome along
250 for that ! Nice buy Smile as bash said stage 1 map and enjoy it
[Image: Cn91r40h.jpg]
Looks decent for £250
Cheers folks, it's not a bad runner, I was told it had maybe be tweaked though it doesn't feel like it (though coming from the BMW I guess that'd be the case).
It's currently a bit broken though, had a go at changing the P bushes, now the subframe is off the car thanks to both captive nuts for the front wishbone bolts coming undone and one of the sleeves from the front bush seizing on to the bolt. Got the parts on order now so should be back on the go through the week.
Bloody thing!
Welcome along, but your pic has failed. Try uploading direct to the forum instead, as it'll load faster, and won't suffer from bandwidth restrictions like those imposed by photobucket. Wink
HERE is a link to help you with our uploader if you get stuck. Smile
Oops! Must have too many pictures, will need to do something about that.
I've uploaded the original picture again.
Welcome!
Fair play! I echo the other comments, that looks quite tidy for £250, what a bargain! Does it have much lacquer peel? Diablos are renowned for it. Wink
