inlet temperature
Has anyone got any idea what temperature a stage 1+  boost reaches
That is a very good question, but I have no idea.
One of the mappers should know.
Ive found some gasket paper thats up to 3mm thick and good too 120 degree's which im sure is more than good enough for an inlet but id like to be sure
Give it a go it might work but it's the pressure that might burst through as there is a long unsupported run at the top.
Its rated to 8 bar so the pressure wont be an issue
Sounds good then.
