Head gasket list
Head gasket list
So going to be doing the head gasket on the 106 and there's a small oil leak coming from it. I've got a list of the only things I can think of.
- Head gasket
- head studs
- cam belt
- water pump
Do I need anything else?
Thank you guys Smile
Head set...for other gaskets and seals etc
Coolant perhaps
Engine oil/filter
Check ya aux belt too...maybe worth doing
hheeellllooooooo did someone say headgasket
[Image: mcetg0.png]
(30-11-2014, 10:05 PM)Piggy Wrote: Head set...for other gaskets and seals etc
Coolant perhaps
Engine oil/filter
Awesome Smile do you think the head will need skimming?
(30-11-2014, 10:20 PM)lolsteve Wrote: hheeellllooooooo did someone say headgasket
Haha lol genuinely made me laugh
Get it checked. If its not overheating and you remove it cold it should be fine though
(30-11-2014, 10:29 PM)Piggy Wrote: Get it checked. If its not overheating and you remove it cold it should be fine though
Yeah it's not over heating at all and only a tiny bit of Mayo and a bit smokey Smile so it should be fixed with a new gasket and all the fluids drained and changed?
I'd take it to an engineers to have it checked my local one doesn't charge for checking just skimming
(30-11-2014, 10:55 PM)306Dan Wrote: I'd take it to an engineers to have it checked my local one doesn't charge for checking just skimming
Cool there's a highly recommended garage by me so I'll take it there and get it checked out
TBH those 8v TU's take a LOT of punishment, I've never NEEDED to get one skimmed, but if it's going to take some serious abuse it may be worth it.
I love these engines in these cars, I've managed a head gasket on one it 45 minutes before now (just ask Ruan!)
Matt-Rallye Wrote:Norledge for prime minister.
Poodle Wrote:I reckon Norledge has got it on the head mind.
Matt-Rallye Wrote:Norledge gets my vote tbh.
Easiest head gasket change in the world...
But yeah, if it's been overheated badly it'll need a skim, if it's not overheated, you'll probably be OK!
(01-12-2014, 08:17 AM)Norledge Wrote: TBH those 8v TU's take a LOT of punishment, I've never NEEDED to get one skimmed, but if it's going to take some serious abuse it may be worth it.
(01-12-2014, 11:56 AM)Ruan Wrote: Easiest head gasket change in the world...
Awesome thanks guys Smile yeah the temp sits just under half way even when giving it some so it should be fine, hopefully there's a thread on here or 106oc on how to change one, never attempted it before
1. Unbolt exhaust manifold from head
2. Drain Coolant
3. Unplug Fuel Pipes/Wiring loom
4. Remove top Cambelt cover
5. Release cambelt tension
6. Undo headbolts
Literally that simple!
(01-12-2014, 01:55 PM)Norledge Wrote: 1. Unbolt exhaust manifold from head
2. Drain Coolant
6. Undo headbolts
Oh haha that's made this job a whole lot nicer. I think I'll enjoy doing this Smile
