	Threads: 36
4 Location: Falkirk scotland
 Car Model/Spec: Berlingo xud / 306 gti6
 Thanks: 5Given 6 thank(s) in 6 post(s)
		Hi I know it's not a 306 but hoping you guys could help.Fitted xud out 405 in ma 03 Berlingo and now messing with fuel and boost. my boost is now hitting 20 psi but don't hold like I have a leak.Tried all intercooler pipes don't think they leaking (fitter front mount).
 So my question is apart from my pipe work can I lose boost some other way
 Thanks
	Threads: 2
		What makes you sure it's a boost leak? I have a xud in my partner. It's mated to standard partner exhaust very restrictive!
	Threads: 7
0 Location: Pembrokeshire, West Wales
 Car Model/Spec: Peugeot Partner
 Thanks: 0Given 1 thank(s) in 1 post(s)
		I may be wrong, but I would have thought that a restrictive exhaust would help hold boost as it couldn't empty the bores quickly enough.
 The wastegate may be the problem, possibly a slightly weak spring, or the wastegate valve/flap burnt away/not seating properly.
 I would check you induction side as well in case there is a restriction. Under initial load, the turbo may be able to cope with the air demand. Under continuous/prolonged load, a restriction on the inlet side pre turbo would starve the turbo of incoming air supply.
	Threads: 87
48 Location: South Yorks.
     Thanks: 2Given 74 thank(s) in 70 post(s)
		No, you want a free flowing exhaust or it can't vent that shizz ?
	Threads: 7
		 (17-11-2014, 11:19 PM)Mattcheese31 Wrote:  No, you want a free flowing exhaust or it can't vent that shizz ?
I agree. To get more air in, you've gotta get the spent gases out. But, in my mind, a restrictive exhaust wouldn't cause boost pressure not to be held.
	Threads: 87
		Exhaust has got f all to do with this problem
54 Location: Cotswolds
       Thanks: 22Given 68 thank(s) in 68 post(s)
		Does it spike to 20psi?If so, what does it then settle at? And what gear/rpm are you testing this with?
	Threads: 226
24 Location: Cornwall
 Car Model/Spec: A3 TDi
		Whats the smoke situation like?
	Threads: 36
		Thanks for replays feel bit stupid now   . I  knew my exhaust would effect it just not that much as it's blowing anyway lol . If i dont  put the foot to floor it holds boost longer . I got bits to make exhaust today
Thanks
	Threads: 87
		 (19-11-2014, 06:46 PM)xudlingo Wrote:  Thanks for replays feel bit stupid now . I  knew my exhaust would effect it just not that much as it's blowing anyway lol . If i dont  put the foot to floor it holds boost longer . I got bits to make exhaust today
 Thanks
who told you to make an exhaust?
	Threads: 36
		Me heard 306 one close what's different
 Thanks
	Threads: 36
		 (15-11-2014, 11:19 AM)daniel.mountain.7 Wrote:  What makes you sure it's a boost leak? I have a xud in my partner. It's mated to standard partner exhaust very restrictive!
Is your partner phase 1 or 2 I got some problems with engine mount not line in up
	Threads: 7
		Does it smoke at all when your foot is hard down? Could possibly be weak mixture if not. @ 20 psi, the boost has obviously been 'adjusted', if the pump hasn't been adjusted/adjusted enough, then it'll be weak under full load at higher revs. Easing off decreases the load and boost, it may well have the correct air fuel mixture then.
 So does it smoke when up the revs (at least 2500rpm) and foot planted hard down?
	Threads: 36
		 (19-11-2014, 08:30 PM)madwelshman Wrote:  Does it smoke at all when your foot is hard down? Could possibly be weak mixture if not. @ 20 psi, the boost has obviously been 'adjusted', if the pump hasn't been adjusted/adjusted enough, then it'll be weak under full load at higher revs. Easing off decreases the load and boost, it may well have the correct air fuel mixture then.
Mixture is not best smokes a bit but gets bad if keep foot down on motorway as boost creeps down can some times go as low as 8psi
I do think it's the exhaust as sounds like it has a supercharger coming out the blowing exhaust. I will rip exhaust off and take it a spin with just downpipe see what happens ( with ear plugs)
Thanks
	Threads: 7
		Is it black smoke or grey? Being a turbocharged engine, it won't be too bad without the exhaust on, especially compared to a n/a engine.
	Threads: 36
		Used to be black but think more grey now after modifying lda
 405 down pipe not right shape so rattles on floor makes a lovely noise not
	Threads: 7
		Is it a light grey? If so, I'd say not getting enough fuel at full boost.
	Threads: 36
		Bit hard to tell as half smoke coming out underneath with blow need to sort exhaust then I can mess with tuning
	Threads: 7
		Fair comment.It might be worth reducing the boost pressure slightly (down to 12-15 psi) to see if it holds more consistently and especially at full throttle up the revs. Either that or not driving it so hard until the exhaust is sorted and you have a better idea of the fueling.
 If it is weak mixture that's causing this, you run the risk of burning out/holing a piston.
	Threads: 2
		 (19-11-2014, 07:47 PM)xudlingo Wrote:   (15-11-2014, 11:19 AM)daniel.mountain.7 Wrote:  What makes you sure it's a boost leak? I have a xud in my partner. It's mated to standard partner exhaust very restrictive! Is your partner phase 1 or 2 I got some problems with engine mount not line in up
What mount are you struggling with? Also what was the original engine?
	Threads: 36
		It is turned back down the now
 The top engine mount is my problem it's to short when I line the  up the back mount and gearbox had to do a temp mod at moment
 I will attach pic
	Threads: 19
12 Location: Devonshire
 Thanks: 4Given 25 thank(s) in 24 post(s)
		20-11-2014, 01:04 PM
(This post was last modified: 20-11-2014, 01:05 PM by mr_fish.)
		On the gearbox mount they should be 'slotted'
 loosen the bolts for it and see if it will move, I had to do this on the 206.
	Threads: 36
		 (20-11-2014, 01:04 PM)mr_fish Wrote:  On the gearbox mount they should be 'slotted'
Did do that but if I line the top engine mount up the back mount hits the sub frame and one shaft to long other to sort .so I went with that option as ever thing else lined up
But I'm sure I saw one in a early Berlingo so the shell must be different or shafts and back and gearbox mount must be different to mine
When I was doing engine though be easy dw8 and xnd so much has been changed
	Threads: 2
		What gearbox is in it? Dw8 box?
	Threads: 36
		 (20-11-2014, 10:52 PM)daniel.mountain.7 Wrote:  What gearbox is in it? Dw8 box?
Tried that fitted everthing  on to 405 engine mounts box clutch etc  had to make lot bits fit. Then found shaft would not go in with Berlin go back mount as the newer boxes put engine bit straighter so box turn maybe 10 degrees so was no good
Wasted my time and put all 405 bits back on apart from power steering and alternator wanted to keep that. Also had to upgrade Berlin go clutch as was so small use a 206 180 clutch and modified flywheel
Peugeot like changing things to much
	Threads: 2
		21-11-2014, 01:11 PM
(This post was last modified: 21-11-2014, 01:13 PM by daniel.mountain.7.)
		I had to change the cv joint to make the drive shaft fit. Changed clutch cable and used xud box. Used 306 power steering pipe. Dropped straight in.
 Used xud down pipe. Welded to partner exhaust.
	Threads: 36
		21-11-2014, 01:14 PM
(This post was last modified: 21-11-2014, 01:22 PM by xudlingo.)
		Has a side exit exhaust for temp exhaust bit loud but turbo sound great out it has helped a lot even hit 22 psi now. But still slowly drops not had lot time to mess with pump yet
Much faster
  (21-11-2014, 01:11 PM)daniel.mountain.7 Wrote:  I had to change the cv joint to make the drive shaft fit. Changed clutch cable and used xud box. Used 306 power steering pipe. Dropped straight in.
Same with cv with me but because mine a mk2 the van it will go in eco mode with no signal from flywheel. So you had done same as me and your top mount fine so my shell must be bit different
They was 2 position on subframe for the fork I had to move that also
	Threads: 119
15 Location: Rotherham/Sheffield
 Car Model/Spec: Ph1 Diablo DT
		i dont know why you are having issues with the fitment of this. As the partner/berlingo from the bulkhead forward is exactly the same as a 306. All the mounts suspension steering rack subrame coolant system wiring is the same. just litterally drop it in. when id converted my old van it was a 405 engine with a 306 dt box. no need to butcher mounts or drive shafts. as for you exhaust issue 306 dt down pipe fits fine
www.prestige-auto-care.co.uk
	Threads: 36
		Yes on the early belingo but the newer one the wiring is like a 206 clocks are out 206 also has bsi . So for some weird reason must move mount on van maybe for the 1.6hdi engine
 I thought it would be as easy as you say it is
	Threads: 2
		Mine is an early one. I wanted to ask about mounts on a 1.6hdi. As IDE like a newer van purely so it's cheaper to tax. But keep the xud. Interesting to know. Does anyone know how much tax is on the 1.6hdi?
